smoke comes out of exhaust
hey i have 92 civic sedan and everytime i rev the engine smoke comes out.. and when its in idle there is smoke too just not noticible
Re: smoke comes out of exhaust (frankcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankcivic »</TD></TR><TR><TD CLASS="quote">i just changed my oil the other day though..
blue smoke</TD></TR></TABLE>
= burning oil. Maybe you have too much.
Re: smoke comes out of exhaust (EG2 SiR)
hmm i think thats the problem too now. becuase i put 3 3/4 qt oil when im supposed to put 3 only?
will the oil burn off by itself?
blue smoke is burning oil. get the oil to the right amount. then see if it still does it i guess. then if it does, do a compression test. oil could be leaking past rings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankcivic »</TD></TR><TR><TD CLASS="quote">how do i get the oil to the right amount? do i just hold the accelerator and burn the oil?</TD></TR></TABLE>
that is now the most retarded thing i have read on here! use the dipstick you dumbass, if it's too high drain some out, don't burn it off, if you run your engine with excess oil you can cause serious damage.
Re: (sleeperciv)
im glad that i entertain you guys
okay i drained some of the oil and theres not as much smoke anymore..
on the lower revs there is no smoke
but on the higher revs there is smoke. do i just keep draining oil until it goes away or just leave it like it is?
any response is appreciated
Re: (EG2 SiR)
okay i checked its about an 1/8" short of the second hole. it smokes when i rev the engine a bit high. my car doesnt have a tachometer but i know im not reving to where it would be redlining.
Re: (frankcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankcivic »</TD></TR><TR><TD CLASS="quote">im glad that i entertain you guys
any response is appreciated</TD></TR></TABLE>
so umm, u sure you know how to check the oil?
there should be a mark where it says full on the dipstick. don't go past this mark. it could hurt the seals in your engine.
so if there's no smoke except when u redline it, could just be running really rich. just a suggestion. wait, that's black smoke, ha.
Duhul
05-20-2010 11:18 AM
