99EX Coupe...Removal of interior panels and back seat?
I haven't been able to find anything on this. Some drunk+stoned idiot backed into me as I was slowly backing out in a parking lot. I was being attentive, but my head was turned the other way because he hadn't even been in reverse when I last looked, and I was looking right behind so that I wouldn't hit any humans with my car.
Well...he hit that back panel that can't be unbolted. I want to come in from the inside and hammer it out and see what I can do. The damage isn't that bad, but it is there. I need to take the back seat out to access the plastic panel with the book holder thing. How do I take out the back seat?...I think that the panel should be self-explanatory.
Also, I looked under the back seat, and there's this orange connector that just sort of goes to nowhere. Is it a sensor of some sort?
Thanks, guys.
Thanks, guys.
Re: 99EX Coupe...Removal of interior panels and back seat? (Mike P.)
yeah...most likely is the fuel pump...in my car that's what is it and that the only wire under the seat
Re: 99EX Coupe...Removal of interior panels and back seat? (parasonic)
Fold the back seat forward, there should be 2 shiny metal brackets (one on each side of the seat) that you just unbolt the seat from, and then just shimmy it out. Bottom seat there is a bolt on the back dead in the center, its fairly obvious. After that tilt the bottom part forward to release the clips holding it to the body, you may have to shimmy it a bit here but its easy.
As for the rear panels...once the seat comes out, theres a screw near the bottom of the panel, on each panel, unscrew and then pull.
From A Buick 8
02-28-2015 06:08 PM
srd05c
Honda Civic (2006 - 2015)
14
06-30-2008 05:19 AM
