Stuck in traffic, car overheating
As soon as I started to drive normally the temp needle went down.
Any ideas on why this would be happening? Any solutions to alleviate this problem?
Re: Stuck in traffic, car overheating (Knocturnal)
i had the same problem, check your coolant , hoses and let the car idle for a while and check to see if your fan comes on, if all that is good change your thermostat, if thats not it your head gasket might be on its way out thats what my problem was. i would check it out asap.
Re: Stuck in traffic, car overheating (COLDDIFFUSION)
to check the thermostat, let your car come up to N.O.T. and check the upper radiator hose, if it's not hot, then your thermostat is stuck closed and needs to be replaced
Re: Stuck in traffic, car overheating (hatchdrvr)
yep. if it is your thermostat, do not buy one at autozone - many are sold as defective (i've got 2). spend the extra 10 bucks and get an oem one.
this one just about sums overheating problems up: https://honda-tech.com/zerothread?id=629882
1)check the fan if it works
2)check coolant level
3)check thermostat
4)check exhaust manifold if there is any coolant/moisture in there. That would indicate that you need to change the head gasket or that the head is warped.
Hope this helps
3)check thermostat
Hope this helps
stocker2shocker91
01-24-2010 02:40 PM
hotcivicsi
11
04-09-2009 06:19 PM
car, civic, del, fan, honda, hondas, overhearts, overheat, overheated, overheating, overheats, sol, solutions, stuck, traffic
