Engine Sputtering
Old Feb 22, 2004 | 01:40 PM
PSU's Avatar
PSU
formerly DxHatchback
Default Engine Sputtering
when i start my car up the engine sputters and when i hit 3,000 rpms it feels like the car loses power
i unhooked the battery terminal to reset the ecu
anyone know what this could be?
EDIT MARCH 10
so far i have changed
-spark plugs
-plug wires
-fuel filter
-cat convertor
-fuel injector cleaner
-89 octane gas from Sunoco (used to run 87)
anyone?
Modified by DxHatchback at 3:18 PM 3/10/2004
Old Feb 22, 2004 | 01:58 PM
2trix's Avatar
Default Re: Engine Sputtering (DxHatchback)
yes! its your flux capacitor!....j/k a little more info needed...what engine, what year...what has been done to it? is this something recent or has it gotten noticably worse over time?....what cels if any?
Old Feb 22, 2004 | 01:59 PM
PSU's Avatar
PSU
Default Re: Engine Sputtering (2trix)
stock d15b7
no mods, just a k&n in box filter
was fine friday, drove it today and it started
Old Feb 22, 2004 | 02:02 PM
ProJectCvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback &raquo;</TD></TR><TR><TD CLASS="quote">stock d15b7
was fine friday, drove it today and it started </TD></TR></TABLE>
I had this problem with this with my old engine too. It turn out that i have oil in my spark plug from leading through the head gasket. Look at your spark plug
Old Feb 22, 2004 | 02:04 PM
dantastic's Avatar
when was the last time u had a tune up? if it has been a while, try changing plugs. wires, rotor and cap
Old Feb 22, 2004 | 02:19 PM
PSU's Avatar
PSU
Default Re: (dantastic)
my uncle said maybe water in the gas?
Old Feb 22, 2004 | 02:53 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (DxHatchback)
It's your ignition coil. Either replace it with OEM or get an MSD BlasterII. Bam.
Old Feb 22, 2004 | 06:13 PM
PSU's Avatar
PSU
Default Re: (Archidictus)
how much are they? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">It's your ignition coil. Either replace it with OEM or get an MSD BlasterII. Bam.</TD></TR></TABLE>
and to the other reply, it wasnt the spark plugs
Old Feb 23, 2004 | 04:49 AM
PSU's Avatar
PSU
water in the gas anyone?
Old Feb 23, 2004 | 01:51 PM
PSU's Avatar
PSU
it's pretty bad when noone can help me with this, yet 1,000,000 people can respond to a stupid picture post of a played out wannabe jdm mobile
Old Feb 23, 2004 | 02:17 PM
nerdsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback &raquo;</TD></TR><TR><TD CLASS="quote">it's pretty bad when noone can help me with this, yet 1,000,000 people can respond to a stupid picture post of a played out wannabe jdm mobile</TD></TR></TABLE>
i feel ya. my friends car is sputtering too... but really bad. it has its days where its fine, then the next it goes nuts and barely drives...... good luck...
Old Feb 23, 2004 | 02:21 PM
singlecam screamer's Avatar
it's got to be a bad coil or some bad gas ,try putting some higher octane fuel in it and see what happens
Old Feb 23, 2004 | 02:23 PM
civboy115's Avatar
Default Re: Engine Sputtering (singlecam screamer)
id have to go with fuel filter. Look at that first before almost anything else. If it hasnt been changed in over 30,000 miles, id go with that....makes all the diff in the world
Old Feb 23, 2004 | 03:03 PM
red91g2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxHatchback &raquo;</TD></TR><TR><TD CLASS="quote">water in the gas anyone? </TD></TR></TABLE>
Anything really could be a factor
Old Feb 23, 2004 | 03:09 PM
PSU's Avatar
PSU
Default Re: Engine Sputtering (b18c93)
thanks guys
i guess ill try the fuel filter and 89 octane gas before anything else
Old Feb 29, 2004 | 03:00 PM
PSU's Avatar
PSU
i changed
-plug wires
-spark plugs
still doing this sputtering to an extent
could it be a clogged cat convertor?
Old Feb 29, 2004 | 10:48 PM
lohatch's Avatar
yes a plug catalytic converter can make the car sputter. also you might want to pull the cap off your dist. and see if there is any dust, debris, etc in there, if so blow it out and maybe whipe it down with a clean paper towel and see if that helps. kinda hard to say what your problem could be but i hope you figure it out
Old Feb 29, 2004 | 11:02 PM
95civicracer's Avatar
maybe bad fuel filter or dirty injectors
not bad but old
Old Feb 29, 2004 | 11:11 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Engine Sputtering (95civicracer)
my car was sputtering today, and i found out it was because my car's been sitting for 2 weeks with old 87 octane. pumped 92 octane and it ran fine again.
Old Mar 1, 2004 | 05:30 AM
PSU's Avatar
PSU
Default Re: Engine Sputtering (AzntaggeR)
i also replaced the fuel filter but it didnt do anything
should i run all the old gas out before i put 89 octane in?
Old Mar 10, 2004 | 11:21 AM
PSU's Avatar
PSU
to the top
Old Mar 10, 2004 | 12:14 PM
PSU's Avatar
PSU
Default Re: Engine Sputtering (nerdsports)
someone has to know
Old May 7, 2004 | 02:20 AM
DragInteg's Avatar
From: MY GIRLFRIENDS MOMS HOUSE, NEW BERLIN, WI, USA
Did you ever figure out the problem? I have the same problem, and know it is not: the gas, the clogged fuel lines, distributer cap, plugs, or wires... the timing is dead on. The only thing left is the ignition coil because it seems to be timing/ignition oriented. It could be the distributer itself but it is pretty new. Higher octane gas did make a difference. The car runs well when really cold (right after start up) but once it is warm, it sputters at start and at about 5 thousand on my D16a6. Help me from your experience.
Old May 7, 2004 | 04:30 AM
Jimmy's Avatar
Global Moderator
I'd either say ignition coil or ignitor.
