Speedometer problem
Old Feb 21, 2004 | 01:07 PM
CivicBoi's Avatar
Default Speedometer problem
98 LX-G Civic.
Speedometer moves when it's on idle. Circles all the way around.
Car is running fine but I don't if the guages are all accurate.
I pulled the odometer counter and when i tried to put it back I got this problem.
Thanks for the help
Old Feb 21, 2004 | 01:09 PM
4everlost's Avatar
Default Re: Speedometer problem (CivicBoi)
sounds like ground or bad connector somewhere. what did you do when it was off?
Old Feb 21, 2004 | 01:14 PM
CivicBoi's Avatar
Default Re: Speedometer problem (blackcap)
Nothing i just wanted to stop the clicks
Old Feb 21, 2004 | 01:51 PM
zelifcam's Avatar
Check connections... sometimes strange things can happen if the connection is open. Make sure the connectors are properly seated. Visually inspect the plastic circuit material on the back of the cluster for broken connections. Verify that the speed pulse signal is getting to the cluster by backprobing the speedometer signal wire with a digital multimeter and watching for any sort of voltage increase with speed. Other than that, you've ruined the speedometer; get a new one.
Old Feb 21, 2004 | 02:00 PM
Discosteak's Avatar
you over tightened your speedo. your going to have to replace it i did it with my fuel guage on my cluster and snapped a very small copper wire
blinger
11
Mar 26, 2024 08:08 PM
afterdark
13
Apr 30, 2009 10:12 AM
eh2ner
10
Jan 23, 2008 12:41 PM
burgandybeast
Nov 2, 2007 02:30 PM
timex_94_CX
10
Sep 16, 2004 06:29 AM
