installed my new LCA's **pics**
Guest
Posts: n/a
i think im maybe the second person on here with megan racing lower control arms because everyone is obsessed with purple srr's. anyway, i received these yesterday. they look like really good quality and they are pretty beefy. they are the same length as the oem's. for $91, these are awesome. i bought these so i could hook up my gsr sway bar. i was suppose to get it yesterday but didnt, hopefully today. anyways heres the pics (yes my car is filthy)
Modified by mike93eh at 5:02 AM 3/12/2004
Re: installed my new LCA's **pics** (mike93eh)
NICE...
I hate those purple SRR's and I don't need camber correction so they'd probobly F-up my alignment...
I might get a set of those... do you know if they come in black?
Re: (ProEater)
yeh i got em on my black EK too... they're nice. notice how they stamped their name on there upside down?
http://www.meganracing.com , if you're going to buy, get em on ebay, its the same people, but different prices, bout $50 cheaper then the retail.
i'm actually considering selling mine, because i was under the impression these were shorter for camber correction. i may end up having to get SRR's, which i was trying to avoid spending that much money on.
Guest
Posts: n/a
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">Looks nice. BTW, did you place a jackstand on the subframe where the LCA's and sway connects to? Is that safe? I was going bonkers the other day on where the hell to place a jackstand if the little bracket where you place the jack itself is already taken.</TD></TR></TABLE>
yup, its safe spot to place the jackstands. well i put them there because i wasnt taking off the wheels so if it did fall i wouldnt get hurt anyways..
or you could put them in front of the rear wheels..
i didnt have to take my wheels off to put these on either, so having 17's sometimes can be nice hehe
Modified by mike93eh at 7:26 PM 2/21/2004
Re: (Dimi)
Jack it up on the rear tow thing, then put the jackstands on the brackets on each side.
Guest
Posts: n/a
Re: (Two_K Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si »</TD></TR><TR><TD CLASS="quote">Nice Are these LCA's any lighter than oem ones? And how are they bushings that come installed in them?</TD></TR></TABLE>
yes they are lighter (aluminum) but dont know how much lighter, i should of weighed them. the bushings are as good, if not better than oems. each one has a allen head set screw for the bushing to make it fast and easy to change a bushing while on the track, as someone said here before. overall they are top notch and worth every bit of $91.
Guest
Posts: n/a
Re: (Awb17x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Awb17x »</TD></TR><TR><TD CLASS="quote">look real nice bro.....where did u get the from again?</TD></TR></TABLE>
ebay
the guy i bought them from and hes the guy who sells them for 92-95's just got his ebay account temporarily suspended for 14 days though. he told me they said he had too many multiple auctions.
http://cgi.ebay.com/ebaymotors...92921
ebay
Re: (handa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">those looks impressive! what colors do srr ones come with?</TD></TR></TABLE>
SRR comes in purple only.
But Perpetual Concepts in the HT sponsor section are able to powdercoat them any color you want for a bit extra. They have great price and great service. Andrew gets a from me.
One of these days i'll get around to putting up info on all the srr stuff i've bought from them.
Guest
Posts: n/a
Re: (daver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daver »</TD></TR><TR><TD CLASS="quote">I'm sorry, what is the purpose of these? The ebay add said they too allow for wider tires and it stops the rubbing.
d</TD></TR></TABLE>
haha thats why you dont read or believe all those item descriptions. i do my own research before i buy something.
EDIT: wow, this is what i found on meganracing.com..
Engine Exhaust System Seats Spolier Suspension
Honda Civic 92-95
Model Number : MR-CA-HC9295-B/R
LCA's are an essential part to your car's suspension. When lowering your car your wheels will start to butterfly inward at the top which makes your tires ride on the edge. This increases wear on your tires as the sidewalls are the weakest part of your tire. This also means that there is less tire on the ground which means loss of traction around turns. LCA's reduce camber so that more of your tire touches the ground, keep your tires from rubbing your fender and allow for a wider wheel and tire combination. These LCA's provide light-weight performance with an enhanced appearance to your suspension. These arms are available in Red and Blue finish.
mine are oem length and dont help camber any. so i dont know what thats all about. i dont care i didnt want them to correct camber.
d</TD></TR></TABLE>
Honda Civic 92-95
Guest
Posts: n/a
Re: (90civichb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichb »</TD></TR><TR><TD CLASS="quote">they sell these LCAs for 93-97 del sol?
I want a set</TD></TR></TABLE>
http://www.meganracing.com/pro...id=65
nope unless they are the same as 92-95 civics...
Re:
I had a 205 40 17 tire before and it doesnt rub my fenders, now that i got some 215 40 17 they rub like crazy will Lca help limit the amount of rubbing? I assume the Lca if shorter pulls the whole rotor, calipar/ etc assembly more inward, am i correct?
Re: Re: (xcivicdx)
i'm also looking for rear lcas that will fit my gsr sway bar on my eg hatch..would i get those megan lcas for a 92-95 civic for a 94-01 integra? thanks in advance! and they loookk great!
Re: Re: (spunky424)
Are LCA's easy to install. Like it's been so long since I lowered a car, so is it
pretty much taking the steps of lowering a car and then placing the LCA's in there.
Also, what's the big deal about these. Like I have a concept of them, but rather be
told right or set in the right path about this item. TIA. Sorry for high jacking the
thread, but I've been very interested.
Re: (mike93eh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">
they are the same.
they are the same.
