Check engine light: code 7(TPS)??
Went to the track today. Check engine light came on when i revved to 8500rpm. First time i've went that hi so far. Oh yeah engine is b18c1 w/ i/h/e, skunk manifold, skunk gears, crower 402a cams, dual springs, titanium retainers, chipped P28 from GBR tuning(5700vtec,9k rev limiter), and 68mm STR TB. I drive it everday. Just recently got the springs and retainers so i went a little higher today on the revs(just 8500). Nothing seems to be acting funny and after i turn the engine off and turn it back on, no CEL. I thought if the voltage from the TPS was wrong it would automatically trigger the CEL upon start up. Not when the throttle is wide open. Should i worry or not since the CEL cuts off when engine is turned off then on again???? One more thing,I ran it at the track before with the chip and factory springs , but never went higher than 8k and CEL never popped on, it just did today when i went pass the stock rev limiter for a b18c1......
Re: Check engine light: code 7(TPS)?? (lilredhatch)
This is probably the wrong forum to post this problem in but the engine is in an EH2 and also this forum seems to be more active than the Tech forum.
Anyone?
Anyone?
GSR_Hatch8
06-18-2010 03:06 PM
null.
10
07-02-2004 05:55 PM
