b16a transplant
b16a transplant troubles
hi. can anyone help? ive put a jdm b16a from a 92 eg9 ferio into my 95 ej2 coupe. having a few problems with the electrical side of things.Everything is conected and the extra wiring in place apart from the oil pressure sensor and knock sensor which need replacing. However on start up,after running fine for about 30 seconds the engine management light comes on and the revs start hunting up an down. Is this fall back mode for the engine? anyone got any ideas/solutions? would be much apprechiated if anyone can help at all.
Re: b16a transplant troubles (chris81)
you need to look above the ECU and jump the srevice connector to see what code you are throwing
it could be anything.
suncoastcustoms
07-19-2004 04:08 AM
