(searched) sporadically soft clutch pedal
so i have been having problems with my clutch pedal. for a while it got softer and softer and after searching HT, i concluded it was the clutch master cylinder and slave cylinder. so yesterday i go to my local auto parts store and score a master/slave cylinder. installed it, bled it, and clutch felt bomb. stiff and catching low as opposed to soft and catching high.
now i dont understand what the problem could be. the only "problem" i had was tightening the clutch line onto the slave cylinder but i resolved it and tightened it as much as i could. i greased up the end of the slave cylinder with whatever grease i could score out of the old one (i didnt have any grease )
also could it be perhaps the master cylinder rod not being lubed be a problem? i cant figure out what the **** the problem could be. i doubt its the clutch lines?
should i just take apart everything and reinstall it? this ******* sucks
come to my rescue HT
Re: (searched) sporadically soft clutch pedal (ixiblindixi)
Try rebleeding the lines before digging any deeper. There might be chance that you have air in the lines.
have you tried flushin the system? my brother-in-laws b16 EG has the same problem.. only with two different engines. we're gonna do the clutch mc this spring.
Re: (searched) sporadically soft clutch pedal (redlinetuning)
before starting this i removed the bleeder valve and flushed as much fluid out as i could. could the problem be that i reused the fluid? also i think ill try bleeding it again tomorrow =/
check your secondary slave cylinder... if theres brake fluid on it then its busted. Happend to me a couple of times.
Re: (searched) sporadically soft clutch pedal (EGCoupe)
thats the one towards the middle of the firewall with clutch line going in and out of it right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ixiblindixi »</TD></TR><TR><TD CLASS="quote">could the problem be that i reused the fluid?</TD></TR></TABLE>
I really don't think that helped. Flush some new fluid in there and see how it does. Valvoline SuperSyn (I believe that's the name) is good stuff.
yea check that slave cylinder. my clutch kept getting softer and softer and engaging lower a while ago- turns out the slave cylinder cracked and leaked fluid/lost pressure in the system
Re: (searched) sporadically soft clutch pedal (blackeg)
i already replaced the clutch slave cylinder. im gona see about this "secondary" slave cylinder tomorrow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ixiblindixi »</TD></TR><TR><TD CLASS="quote">i already replaced the clutch slave cylinder. im gona see about this "secondary" slave cylinder tomorrow
ahh ok- good luck man
Re: (searched) sporadically soft clutch pedal (thenick)
Any luck? I've been having the same problem, and I'm hoping to find out what it is. Thanks.
Re: (searched) sporadically soft clutch pedal (dokesdc2)
Did you bench bleed the M/S before you installed it?
Why would you re-use the same fluid?
Also, your slave was most likely okay. usually the M/S goes out, not the slave. I would have tried to replace that first.
gooblinn258
01-18-2014 05:02 PM
FuNkDrSpOt
10-10-2006 09:48 PM
