D16Z6 vtec engagement? Which rpm?
Does anyone know the rpm that vtec gets activated on a D16Z6?
I ve heard people say 5000 - 5500...but iam looking for a specific number.
Re: D16Z6 vtec engagement? Which rpm? (Cee_mon)
On a stock D16Z6, it's 4800 RPM. I've made a DIY VTEC indicator light, and everytime it never fails to light up at 4800 RPM.
Re: (TranceadikT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TranceadikT »</TD></TR><TR><TD CLASS="quote">ive heard 4800 or 4900 for z6 and 5500 for y8. my z6 def comes on at 4800 or 4900, i have a vtec light and i can also hear it very loud with my cam</TD></TR></TABLE>
yea this is right
yea this is right
Re: (Re3irth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Re3irth »</TD></TR><TR><TD CLASS="quote">the EX engine is the y8 right or the other one?</TD></TR></TABLE>
92-95 EX - D16Z6
96-00 EX - D16Y8
92-95 EX - D16Z6
96-00 EX - D16Y8
istead of a pop it just gets louder. what you should do if u really want to hear is it just take off your muffler. run open axle back, you should be definately be able to here it then
Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">istead of a pop it just gets louder. what you should do if u really want to hear is it just take off your muffler. run open axle back, you should be definately be able to here it then</TD></TR></TABLE>
sohc's dont have vtec on the exhaust side so taking off the muffler wont make a damn bit of difference. the sound is all in the intake, especially if you have a cam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">i think it varys on oil pressure,throttle position, and engine tempature. I could be wrong, but these are factors to vtec.</TD></TR></TABLE>
this is true, but at normal operating temp and at wot vtec engages at 4800-4900 on a d16z6.
Re: (sohcvtec1995)
Engine temp and vehicle speed (I think it's 135 deg F and 19 MPH) determine whether or not VTEC will engage, but have no effect on what RPM it will engage at. Engagment RPM is programmed into the ECU.
D16z6 on stock P28 = 4800 RPM VTEC engagment.
EDIT: I think adequate oil pressure may be needed too. ...Not sure, my FSM is out in the car.
Modified by OBD1Kenobe at 5:03 PM 4/15/2004
VTEC doesn't engage at the same RPM everytime. Its all on oil pressure, speed, and sometimes temperature (cause your VTEC wont hit when its ice cold). That is why everyone is posting different times when there VTEC engages.
Re: D16Z6 vtec engagement? Which rpm? (MikeNice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeNice »</TD></TR><TR><TD CLASS="quote">VTEC doesn't engage at the same RPM everytime. </TD></TR></TABLE>
You are incorrect.
You are incorrect.
be professional
The D16Z6 engages VTEC at 4800 RPM.
NOTE to those of you posting 5000+ RPM numbers: The D16Z6 and D16Y8 DO NOT have the same VTEC engagement points!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBD1Kenobe »</TD></TR><TR><TD CLASS="quote">
You are incorrect.</TD></TR></TABLE>
Care to elaborate on how he is incorrect?
