d16y8 oil pan on a d16z6?
what up peeps, My engine is being built and is almost done, but I have a question for you guys regarding the oil pan. I purchased a d16y8 oil pan because I sold my d16z6 pan along with my turbo setup, and also wanted to use the d16y8 pan cause its aluminum and I hered its better than any of the d16's oil pan, now I searched and hered people saying thats it different from the other d sereies oil pan but would like to know if theres anyway I can make it fit or if anyone has done this to their d16z6, any info would be great..thanks guys.
Former Moderator
Re: d16y8 oil pan on a d16z6? (solsi2000)
No they don't interchange.
Hell the aluminum pans are designed to not even use a pan gasket, only Hondabond and a small half moon gasket, while the steel pans require a gasket. The blocks are different in this respect too I'd imagine.
Re: d16y8 oil pan on a d16z6? (gabspeed)
yeah that should be the same. it's like the same block. almost lol but it won't fit on the z6 block cuz the changed a some parts as the years pased, (like the water pump) (diff. bolt pattern) O yeah quick quest. does any one know if the y8 oil pump is diff. from a zc 89 oil pump. ???????????????????????????????????????
