is there any other hardware to use to put a lip on *PIC
while i wait for my lip sir lip i was wondering what else is there to use to put my c/f lip on for the meantime....
zip ties and pimp *** shoelaces with sparkles the middle
Modified by ek_jeremy at 12:17 AM 4/17/2004
Re: is there any other hardware to use to put a lip on *PIC (ek_jeremy)
LOL
no that will hold fine, and that shoe lace is mad JDM Yo
I hope your kiddin, but if not, use 2 screws on each side of the lip, having 2 people makes it go on much easyer, and put 2 to 6 under the lip, so people can't rip it off, 2x sided tap works good as well
Re: is there any other hardware to use to put a lip on *PIC (Quad-Damge)
there is no hole on the side....i am afraid to crack the lip
anything similar like the honda hardware that comes with stock lips
Re: is there any other hardware to use to put a lip on *PIC (jL iLLuZiOnz 9)
Im suprised you made it to the gas station like that, congrats man.
But yea there should be 5 holes on the bottom and 2 on the side.
What you could do if your afraid to crack the lip is mark where the holes need to be (if there no there) and take the lip off. Then slowly drill from the inside out. Atleast thats how your suppose to do it for CF hoods, should be ok with Lips too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy »</TD></TR><TR><TD CLASS="quote">there is no hole on the side....i am afraid to crack the lip </TD></TR></TABLE>
Just carefully drill a small one.
Brian
Brian
yeah something small that would be able to go through both the lip and the bumper...something of oem quality will work fine. As far as cracking the lip...its a carbon fiber lip...they are high maintenance.
youre goin to have to drill some holes in it
like I said in your classified want ad, I should have some oem lip mounting hardware since my lip was killed recently.
haha looks pimp with the shoelaces....
but if you just take a real small bit on the drill you could put a small hole in each side and attach it to the bumper that way with two bolts, and in the middle you could use some double sided tape.
Location: Seattle/Ligonier, WA/PA, United States of Honda
ya defently go with the screws i would not recomened tape at all my friend had his front lip taped on his integra and was going like 130 and it flew off underneth his car anf fucked that up and his side skirts got huge cracks in them.
you use 2 TAPERED screws on each side where the wheel/fender well is. then you use regular bolts for the bottom. Drill slowly and make sure to have a friend with you and for more precausion tape around the area you're going to drill to prevent it from craking the surface area.
Re: is there any other hardware to use to put a lip on *PIC (da935oul)
haha thanks for the info....just got my car out of the shop and had to test out my new lip for a hour or two
Re: is there any other hardware to use to put a lip on *PIC (Sc2_Dan)
those were the best i can get..i have pink zip ties at least..there is some silver sprinkles on the laces though
Re: (enkei rpf1)
you can try using 3m double sided tape and drill small holes on the side .....when i had my wings west rs lip...that how it was installed....the 3m tape held really good.....
daiyama writeup
https://honda-tech.com/zerothread?id=833888
for sale
https://honda-tech.com/zerothread?id=831095
daiyama writeup
for sale
