air not working. need help
so all of a sudden my air is not working in my 95 cx. the heat and the the cold air (no ac) dont work when i turn them on. the weird thing is that when its off some air does blow through, hot when its on hot and cold when its on cold? whats going on? no check engine light. thanks for the help
Re: air not working. need help (ls95hatch)
im sorry but huh? i got pretty confused... but from what i made out...
yes there will always be some kind of air coming in regardless if you have it on or not... the fresh air button... is the **** broken?? ac filled up?? loose wiring??
Re: air not working. need help (Mike813)
i dont have ac. if the fuse was blown, wood the check engine light come on? that could be a possibility i think
I don't think the check engine light would come on for a fuse unless it's a vital one. I'd check the fuses first.
have you opened it up to check for loose wiring?
and try to unplug the ***** and look at em... they tend to crack and dont turn the metal **** behind it..
