HELP WITH SPRINGS!!
HELP WITH SPRINGS!!
im not sure what springs go in front and what springs go in the rear.
the springs are Rs*r, the down springs
2 have flat top ends and are narrower at the bottom
2 look like normal springs. the bottoms are wider, and the tops are rounded, not flat.
does anyone know what ones go in the front and back? it would really help me out, thanks
Re: HELP WITH SPRINGS!! (krazynub)
My spings had LR and RR indicating left and right rears and FR and FF for front right and left. Have you looked over them thoroughly for any lettering?
are two of them longer than the other two? if so the longer ones go in the front and the shorter ones go in the back. hope that helps
Re: HELP WITH SPRINGS!! (hatchi)
are you guys serious? i thought longer ones goes to the rear(but mine are teins though)..because front drop are more than rear. but i'm not sure. there are supposed to be labelled or just give a call the RS*R distibutor for technical assitance. don't take anybody's word for granted.
Re: HELP WITH SPRINGS!! (atermizi)
also if the diameter of the spring coil is thicker on a set of springs, then that is also a tell tell sign of the springs that are supposed to be on the front.
New User
asnkasper
Honda S2000
16
10-22-2017 09:28 AM
ozh_hawaiian
09-10-2010 11:58 AM
EM1 Loi
09-16-2004 12:55 AM
