gsr O2 censor question?
I just finished the gsr swap into a 93 hatch dx. The car runs and drives but idles really low...It also will cut off if reve to high and let off the gas. I had the O2 censor hooked up the stock gsr wire harness under the car and it still would cut off. I unplugged it and there was no change in performance. I don' think the O2 censor is hooked up. Could that be the problem? I am using the gsr engine wire harness and a P72 ecu. Do I have to run wire from the O2 to the ecu harness?
Re: gsr O2 censor question? (pnltnc)
If you've got the GSR engine harness, and a GSR O2 sensor, then no... you don't have to run any wires.
I don't think the sensor is your problem.
Sleepy_Red_hatch
08-08-2005 12:22 PM
1fstevo
10-30-2001 10:13 PM
