wire up abs in a non abs car
Old 04-05-2013, 08:10 AM
nonpoint986's Avatar
Default wire up abs in a non abs car
I want to utilize the hondata traction control module that just came out. I have the s300 and a 97 ex with a p28ecu. Will I be able to order some sensors and just wire them into my ecu? Or does it get more complicated than that?
Old 04-05-2013, 08:23 AM
The Grumpiest
grumblemarc's Avatar
Default Re: wire up abs in a non abs car
You don't get ABS just by adding sensors.
Old 04-05-2013, 08:32 AM
kyden's Avatar
he doesn't want ABS. he just needs a rear abs signal for the traction control unit.
to get that sensor in, you're gonna have to drill and tap the hole for the sensor, along with using an ABS hub.
Old 04-05-2013, 08:39 AM
The Grumpiest
I'm aware but still not as simple as it sounds.
Old 04-05-2013, 08:40 AM
jbpnoman's Avatar
Hondata's TCM doesn't need factory ABS. There are optional sensors available through Hondata (as well as a couple other companies) that will plug in for the TCM to read. If you have an LSD, you can get away with one sensor. If you don't, you'll need two.
It's actually quite simple to set all of this up.
Old 04-05-2013, 08:45 AM
The Grumpiest
Learned something new.
Old 04-05-2013, 08:55 AM
jbpnoman's Avatar
It's actually a really cool system. It's not traction control in the sense of ABS (it doesn't give a **** about the brakes), it can just use the ABS signal if you have it. It also isn't like traction control on 99% of factory cars where it exists as a safety feature. It doesn't gimp the car to worthless as soon as it thinks you're losing traction. It functions more like launch control on high end cars - you keep your foot down, it does the hard work for you.
Old 04-05-2013, 09:05 AM
The Grumpiest
I'm looking into it as we speak.
Old 04-05-2013, 10:55 AM
So I called king motorsports and they had some good info also. All ya need is to make sure that you have the appropriate hubs to fit the sensors and prepare to drill and tap into your hubs. Otherwise abs Sensors can be found pretty easy. For best results you want it on all wheels of course. Also helps in autocross so now you can't oversteer into a tree lol
Old 04-05-2013, 11:17 AM
Could I just use a integra gsr abs sensor and hub Assembly for the back? I believe I have a gsr rear disk kit sitting in my garage. Could just wide it up in the front.
Old 04-05-2013, 01:26 PM
Seagull Management
94EG8's Avatar
You'll need ABS hubs in the back and ABS axles in the front, or at the very least tone rings off both.
Old 04-05-2013, 01:36 PM
jbpnoman's Avatar
You'll only need those parts if you plan on using the OEM bastardization your shop mentioned. There are other alternatives, like I mentioned. Make sure you look into all of your options before latching onto one.
Old 04-05-2013, 03:20 PM
Oh look, I can change this
deschlong's Avatar
Neat stuff. How does this Hondata system compare to the OEM TCS that came on some JDM EG6/9 Civics? Any ideas?
Old 04-05-2013, 03:23 PM
jbpnoman's Avatar
Assuming the factory TCS is like every other factory TCS on every car that doesn't cost a small fortune, they're in completely different leagues. One is made to gimp the car for safety, the other is made to make it easier to go stupidly fast.
Old 04-05-2013, 03:28 PM
deschlong's Avatar
I guess that's what I was getting at: Given the feature was only available on the top-market EGs (versus the grocery getters), is it undoubtedly correct that they implemented it to 'gimp' the car? Not a lot of ppl on this board with first-hand experience with this feature on these EGs, but I guess I wouldn't be surprised if it's the 'gimp' option.
Old 04-05-2013, 03:32 PM
jbpnoman's Avatar
I don't even think proper race-oriented TCS were available on truly high end cars until fairly recently. They were used in the early 90's in F1, but were stupidly complicated, and banned. They were only re-allowed in 2002. Since you're talking 92-95, I'm really inclined to say they're the "gimp the car" kind, and were only included because the top-market trims had the power to warrant it, for safety.
And no, I didn't know the F1 stuff off the top of my head, I had to Google it for reference
chazt
Honda CR-V & Element
04-16-2013 01:04 PM
josh-roy
07-30-2010 02:32 AM
skiptomylou
04-13-2006 06:09 AM
darockstar
03-11-2006 07:26 PM
Fraggle
11-02-2003 11:03 AM
Quick Reply: wire up abs in a non abs car
