B16a2 OBD2b swap into 93 Dx Coupe Help!!!
B16a2 OBD2b swap into 93 Dx Coupe + OBD2 to OBD1 Alternator Mod!!!
I completely understand the bracket and mounts combo I need.
That is the 3 post bracket, dc2 t-bracket, and mounts like these:
I was wondering what would be the easiest yet most efficient way of wiring up the motor. Motor is a b16a2 obd2b going into a 93 Civic Dx coupe. The goal is to convert to OBD1 using a chipped p28 that I plan on sending to [http://www.j-k-tuning.com/ecu-chipping.php] because it seems to be the cheapest Ive found
I have the complete wiring harness from both the cars. the B16 is a complete and full swap.(alt, dist, compressor ect.)
Also, could I use by stock radiator, if so do I need to change hoses? part numbers? And are there other little tricks like that.
I do have this that I was going to use on a previous build [3rd item down] named: "OBD1 SOHC VTEC/Mini Me subharness " Could/Would I need to use this to wire up VTEC?
https://sites.google.com/site/hondapartshero/products
I have heard I might need this "Distributor Jumper Harness" : http://passwordjdm.com/PasswordJDM-D...P1881C320.aspx
^ But I am confused with that Item which is why I need to know if I MUST use it, which harness should I wire the motor up with (b16 or stock Dx harness) and how
If anyone recommends any additional parts or anything any info I'd greatly appreciate it because the threads I've tried to study seem to be hit or miss.
Thanks to everyone checking this thread out and maybe with the right info It actually be helpfully to others
Re: B16a2 OBD2b swap into 93 Dx Coupe Help!!!
the easiest for you would be to use an obd2 integra harness and wire accordingly, as obd2 distributor, injectors, alternator all have different plugs than obd1.
If you loved me, you'd all sell me your magic cards to me today
Couldn't he also swap to OBD1 distributor, injectors, and alternator?
Technical Hero
Check out my thread for your options
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
Thanks so much you guys, really helpful
[QUOTE=94EG8;48639240]The cabin harness (which the ECU plugs are attached to) is still going to OBD1
Oh nice! I'd completely do that if I had the money to get another harness. I'm just broke and trying to get this to work mostly with the parts I've got. Great info though
Have any of you guys done or heard of either swapping the plugs of an alt, say soldering an obd2 plug onto an obd1 harness? Or swapping out the insides?
Seagull Management
Also note that in the case of the alternator you can only swap guts if they're the same brand.
Wow, really, Reading some of these comments.
Dont give yourself a head ache.
Just use the your stock harness thats in it now. The only thing you have to add is 3 wires for the vtec. You can make your own, using the wiring from the obd 2 harness or you can order it for maybe 30.00 now. It should be that cheap.
You may have to switch the Dizzy but if i remember correctly i just used the DX one. Two of the tabs will only bolt up. ( Not a big deal )
And you shouldnt have to switch injectors, the only diff. is the tabs in the harness. Just use a file or a pair of dikes.
The Trans mount will bolt up, The rear might.
The drivers side will not. ( if this obd2 engine is coming out of a CIVIC SI, the SI uses the circle mount.
Go on ebay and buy a 94-01 Integra drivers side engine mount and rear engine mount ( if the rear engine mount doesnt fit but it should)
Its been a long time since i had an EG swapped civic ( maybe 6 or 7 yrs )
Is it possible to swap the guts out if they go to different motors? What Im saying is, is it possible to swap the B16a2 obd2 dizzy guts into the D15b7 obd1 casing or shell?
Really appreciate the info!
Don't give yourself a head ache.
Just use the your stock harness that's in it now. The only thing you have to add is 3 wires for the vtec. You can make your own, using the wiring from the obd 2 harness or you can order it for maybe 30.00 now. It should be that cheap.
And you shouldn't have to switch injectors, the only diff. is the tabs in the harness. Just use a file or a pair of dikes.
Go on ebay and buy a 94-01 Integra drivers side engine mount and rear engine mount ( if the rear engine mount doesn't fit but it should)
So you're saying its possible to bolt the obd1 non-vtec dizzy i have on my D15b7 onto the B16a2 and it will work but not line up correctly?
Seagull Management
But as for the alternators, how did you go about opening the OBD1 alt? Do you have to hit the bolt that is holding on the pully wheel with air and then it will be able to pull apart?
The OBD2 alt opened right up and i can see where you swap out the plug.
Thank so much for the help, its coming along!
Seagull Management
Pics of the two alternators? They need to be the same brand, and the back will look the same if they are. Denso comes apart different than Mitsubishi.
http://www.rywire.com/catalog/obd0-o...pter-p-34.html
Heres a pic OBD2 on left. OBD1 on the Right:
Seagull Management
You can order a Harness or order a voltage regulator for a '92 - '95 Integra from a starter and alternator shop, sometimes they aren't that expensive. As a rule Denso parts are readily available.
Fish Twig
I can confirm that ANY obd2 integra engine harness will plug into ANY obd1 integra or civic, even the del sol. All he will need to do is either get a chipped ecu or find the original obd1 b16 ecu to plug into the cx. I think he might have to run xtra wires for knock and vtec on the shock tower harness. Can't remember.
My only question is how is it guaranteed to either be a Denso voltage reg. or fit a Denso alt??
Seagull Management
Take the OBD2 denso regulator with you, the OBD1 version looks exactly the same other than the plug will be round.
