d16y8 head removal
Re: d16y8 head removal
there's braket the hold the IM to the block. it also won't let you back off the im very far. get under the car and have a look. there one or 2 bolts on the under side also make sure you undid those.
I believe I seen one halfway on the intake manifold that I can get from the top just don't know if I will be able to put back on cant get under my car atm any suggestions?
What you are attempting was not designed to be attempted with the engine in the car, but it can be done with the right tools.
Why do I sense you are attempting this without having looked at a service manual? A manual will detail the cylinder head removal process.
cause I don't have a manual but I got it remove and head changed out just fine without it thanks to a few guys on this site so why spend the money on a manual but thanks for your imput anyway.
OP the bolts can be got with an ratcheting wrench(skinnier than a whole ratchet). as for the bracket you'll NEED to get under the car to remove the bolts holding it.
If you take the bracket off ... dont put it back on..... most people that do mini me swaps etc always throw that bracket to the side for a paper wieght. that bracket is pointless and it would be more useful as a paper wieght.
