93 civic Si rim size help
Ok I'm ordering some stance rims with custom spec can I go 15/10 +12 offset in the rear without using spacer and not a huge amount of camber? And will I have to roll the crap out my fenders
Re: 93 civic Si rim size help
15x10 +12
you will not need spacers. when you're going with low offset wheels. and as low as you're going. spacers will only make it poke more.
you will need quite a bit of camber. I'd say about -5. depending on how low the car will be for clearance.
I'd say. roll the fenders. and you need to test fit. no way of really saying until its put on.
15x10? What crack are you smoking? Why would you run such stupidly wide wheels? We all know you're only going to run stupidly and dangerously thin tires on them.
