1992 Honda civic trouble starting
1992 Honda Civic LX L4 - 1.5L 1493cc type D15B7 - MFI SOHC
I finally got my car running (started). Changed fuel pump. Changed relay. Pump primes. Car starts. Now it takes 10 minutes for pump to prime and run. I feel that it will just not start at all, eventually. My ECM looks to be my problem, I think. does anyone know how to test it out without getting another one? Or any idea of what is going on?
Re: 1992 Honda civic trouble starting
Is the G101 groound the only ground for the ECU? It seems like only the blue/white wire from ECU don't go on, but the ECU gets power. That is my outlook on my problem.
New here, and to Hondas~ but the guy I got my car thru is the premiere Honda wizard in a 3-county radius. If getting fuel on startup is your issue, a common problem with these is the main relay, tucked up under dash by your left foot. They're pricey little buggers, so he gave me a small wire to jump the fuel pump primer circuit when the occasional no-start occurs~ but it's only happened once, and darned if I remember which two terminals to jump. I'm thinkin a $5 momentary switch (versus a $60 relay) to circumvent the issue for the time being.... Hope this helps... somebody....
lledcomp
04-05-2007 06:20 PM
