Help Please! Fuel Not Priming
So I swapped a d16y7(block/y8(head) into my ej8, with everything plugged in, my fuel isn't priming. What could be the cause(s)??
Fuel pump fuse 13 is good, I replaced the fuel pump relay and tried it again, but no go.
Next I'm going to replace the fuel pump and fuel filter.
What other solutions could there be? Thanks guys!
Re: Help Please! Fuel Not Priming
And also! My car had ev6 fuel injector wires setup from past turbo system so I had to splice d16z6 fuel injector harness pigtails and use the z6 fuel injectors. What is the wiring diagram for fuel injectors supposed to be from left to right or vice versa??
Again, thanks.
Again, thanks.
Thanks guys, motor runs! One question though. How bad does timing affect the engine?? And how can I check it's correctly placed?
Cameron60
01-16-2007 06:04 PM
HondaEF
07-19-2004 06:34 AM
