Weird idle?
Weird idle?
Hi i have a eg hatch 94 si with a d15b and a z6 head running a p28 and a greddy fuel management system. ( this all came with the car when I bought it)
I just replaced the battery, engine oil n filter , spark plugs, spark plug wires.
And when the car is turned on this is the idle.. It goes from 1000-0 rpm and just keeps bouncing loke that then 30 secs later it goes to around... 1300 rpm. Ill upload vid real soon.
Re: Weird idle?
Also, Im wondering if this has anything to do with it? i found a hose blocked off with a nut and i followed it back to the canister back down there seen in pictures.
Re: Weird idle?
to hard to see from that pic but i'd guess it's leading to you'r evap system.
also:Greddy fuel system what do you mean what component is from Greddy
Re: Weird idle?
ugh my integra gs-r does that(idle pluse/almost choke out) i've posted in the integra section many a time....we've come no where. does you'r car do it only when cold ? mine did inprove when i threw in known good ls injectors(got them for free)
here's what mine was like
Re: Weird idle?
here's what mine was like Strange idle drop b18c1 94 gsr - YouTube
Yeahhh!! Only when its cold, someone told me to clean the IACV, FITV. Ill try that and post an updated vid on the car. Hopefully this works. You should try it out as well. Especially the IACV
Re: Weird idle?
I've cleaned the IACV countless times. my aftermarket TB doesn't use a FITV but that
Re: Weird idle?
here:http://www.superhonda.com/forum/f55/...n-test-124194/ it's very easy tester can be got at autozone for 20 bucks or so.
Re: Weird idle?
Re: Weird idle?
Re: Weird idle?
You mean the intake manifold. I wouldn't correct, but don't want OP to get confused.
