Engine rocking back and forth...what to check out? EG hatch / b18c
I can feel a slight amount of rocking when transitioning from no throttle to part throttle during low speed cruising. Its just a bit like a hesitation and you can feel the motor shift, though not very much.
What should I be looking for? Any common problems that cause this to occur?
I know i should check out the motor mounts. But what specific problems should i be looking for? Any other ideas to check out while I am looking for the problem area/s
Re: Engine rocking back and forth...what to check out? EG hatch / b18c (son of light)
Im having the same problems, same motor too, B18c.
My problem (might not be the same as yours) is i need new spark plugs and wires. I would suggest you look into those first. Just my .02
check your rear mount. and all other mounts while you at it. defintely the 2 torque mounts are busted.
Re: Engine rocking back and forth...what to check out? EG hatch / b18c (2lua)
Any more info on checking the torque mounts?
also...what does a tuneup have to do with the engine rocking back and forth! lol
thanks for the reply's
order some torue mounts from http://www.jimfab.com they are great hell knock yourself out and get a rear mount too just because i said so
