bov sound..but no turbo?? help
i have a blowoff valve sound somewhere everytime i shift especilly btw 1st and 2nd and 2nd and 3rd...and in the higher rpms from 3rd to 4th....i dont know where its comign from...when the car is on and idling and i rev it ...no bov sound..but when i drive it....it goes pssssh everytime i shift...anyone have any ideas?
Re: (djfob)
Yep.. mine does it. but i can only hear it if bogg it down in like 4th give it some gas then let off and you can hear a little psshh.
BTW short ram intake
Re: (Ape)
I'm going with clogged fuel injector. I had the same sound until I ran some Lucas fuel additive throught my fuel tank. Now the sound is gone. And yes, I have a short ram intake. Also, I went from 300 miles/tank before Lucas to (I've only been through one tank since I put it in) 344 miles on the tank I raced on. Give it a try.
Former Moderator
Re: bov sound..but no turbo?? help (spunky424)
I'll say it's the exhuast manifold/header separating from the catalytic convertor between shifts where the spring bolts are.
Mine used to do it a lot before I got poly engine mount inserts.
Re: (jdmspec1122)
When I saw the title of this thread I thought he has purchased one of those damn BOV sounds simulators. I was about to flame it.
But it most likely is you're intake.
-Addict
-Addict
Re: (Hatch Addict)
Do you still have AC? Does your AC have the pieces that you use to refill capped?
When i had my AC whenever i had it on and i would rev it would sound like a BOV. If i open my hood and uncap it i could even see it purge some freeon. I think my needle was broken, i never fixed it because i pulled the AC. But i would check that if you have it.
i think its the intake. my friend's intake does the same thing. he doesn't have the hose that connect from the intake to the engine, so it makes a whistling sound.
Re: bov sound..but no turbo?? help (jL iLLuZiOnz 9)
thanx for all the quick replies....i do have a 3" short ram intake and i jus put in a type r header with test pipe....still making the noise though...only when its in gear..
like a guy said earlier...i had the problem with the header seperating a bit from the cat when i drove and it made that sound, but not when revving it.
I had that sound when I got my magnaflow muffler put on. I don't know why it did it or what was causing it but it eventually went away. Did you get a new muffler?
Re: bov sound..but no turbo?? help (93civic_sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civic_sedan »</TD></TR><TR><TD CLASS="quote">My civic use to do it and I only noticed it after I got a short ram intake...</TD></TR></TABLE>
Yup yup. Me too...
Yup yup. Me too...
Re: (Hatch Addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch Addict »</TD></TR><TR><TD CLASS="quote">When I saw the title of this thread I thought he has purchased one of those damn BOV sounds simulators. I was about to flame it.
-Addict</TD></TR></TABLE>
There is a guy at my work who has one of those on his MUSTANG!!! I make fun of him all the time. He also has a red neon underbody kit and wants to get the plastic intercooler. What is really bad is he has a built NA motor and puts down 370 to the wheels.
Matt
Matt
Re: (allmotorEG-SI)
nah i didnt get a new muffler..my current setup is a skunk2 megapower exhaust with a testpipe and jdm 4-1 integra headers....before i had stock b16 headers and stock cat with the skunk2 exhaust and no bov sound....always had the short ram intake....wondering if the bigger diameter of 2.5" of the testpipe and header would cause this sound? thanx alot
Re: (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">do you have the HOLES in your intake plugged off? or are they open? </TD></TR></TABLE>
nope holes on the intake are sealed..only have one connected to the valve cover
