clicking noise
Old 04-23-2004, 03:54 PM
pburke23's Avatar
Default clicking noise
Hey guys, heres the prob..when i got in my car today, and started it up, I noticed a little clicking noise, drove it for a little bit, thinking it would go away but it didnt.
So it put it in accessory mode, and turned my music off to listen, and its 2 little clicking noises, they happen about every 6 or so seconds....coming from the same place the clicking noise when your turn signal is on comes from... any ideas?
Old 04-23-2004, 04:20 PM
pburke23's Avatar
Default Re: clicking noise (pburke23)
bump..
Old 04-23-2004, 05:42 PM
pburke23's Avatar
anyone know??
Old 04-23-2004, 05:46 PM
WhiteEG6's Avatar
Main Relay?? Is the sound coming from near the fuse box area?
Old 04-23-2004, 05:51 PM
poison's Avatar
Does this happen when you turn on your turn signals only?
Sounds maybe like the main relay, or a window relay, etc..
Describe more in depth..
Old 04-23-2004, 06:45 PM
pburke23's Avatar
Default Re: clicking noise (poison)
no, it doesnt happen when i turn on the signals. Just while the car is on, from right when i turn it on till it turns off. Two short clicking sounds, from right next to the fuse box somewhere, just a TICK...TICK.. then 4 or 5 seconds later, the same TICK...TICK. Also, the SRS button my dash stays on. Any ideas?
Old 04-23-2004, 09:27 PM
pburke23's Avatar
bump....
Old 04-24-2004, 06:21 AM
EK45VTi's Avatar
"SRS initializaton failure" can be your problem... go to your local Honda garage so they can check your airbag system...
Or try to DIY... check any unplugged cables under the steering wheel and behind the glove compartment, check the SRS fuse and visualy inspect wiring in general... maybe you notice the problem and solve it but I seriously doubt it...
I would rather go to Honda garage and repair it.
Old 04-24-2004, 08:49 AM
pburke23's Avatar
Default Re: clicking noise (KKVTi)
thank you, and bump for any more ideas it might be...would it be bad to drive with it like this for a while?
Old 04-24-2004, 11:22 AM
pburke23's Avatar
bump again, sorry.
Old 04-24-2004, 12:31 PM
pburke23's Avatar
so i was reading through my manual lookin for a possible prob..and came across the fuses for the SRS, decided to check them just in case something had happened. Looked fine, so i put them back in, after that, turned on the car...and the clicking noise was gone....the SRS light is still on, but the noise stopped...hmm..
gqstatus05
12-02-2014 11:07 AM
marine0621usmc
08-17-2010 06:09 AM
RACERX72
09-21-2005 01:12 PM
hnp5
09-01-2005 10:03 PM
mr poo
13
10-19-2003 07:24 PM
Quick Reply: clicking noise
