valvetrain help!!
valvetrain help!!
im buying a set of crane stage 2 cams for my 2000 civic si PN 253-0012. i have adj gears. the only thing i will need is some valvesprings and retainers. i wanted to know what my options are. the only thing i am worried about is getting too stiff of a spring. i heard that too stiff of a spring will reduce cam life, or break it. basically, cranes website reccommends using their own springs/retainers PN 903-2006. here are the specs.
outside dia. 1.169
inside dia. 0.673
seat pressure 80# @ 1.338
open pressure 180# @ .865
coil bind 0.834
rate 227
max net lift 0.473
i want to find something comparible to these. please help.
p.s. if someone has these for sale, or any thing close, let me know.
Modified by staticchmbr at 4:35 PM 4/23/2004
outside dia. 1.169
inside dia. 0.673
coil bind 0.834
rate 227
max net lift 0.473
Re: valvetrain help!! (staticchmbr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticchmbr »</TD></TR><TR><TD CLASS="quote"> the only thing i will need is some valvesprings and retainers. i wanted to know what my options are. the only thing i am worried about is getting too stiff of a spring. i heard that too stiff of a spring will reduce cam life, or break it. basically, cranes website reccommends using their own springs/retainers PN 903-2006.
Modified by staticchmbr at 4:35 PM 4/23/2004</TD></TR></TABLE>
just wanted to know some options. the valvespring/retainer combo from crane costs more than their cams. i want to find a used set, new set, or a cheaper set that is just as reliable and/or has the same specs.
i found a set of valvesprings and reatainers that may work for me..
http://cgi.ebay.com/ebaymotors...%3AIT
they are 16 outer integra type r valvesprings, and 16 portflow inner valvesprings. they said they can be used for high lift cams, or stock honda cams. i think i might buy these. they also come with titanium retainers. $250 + $10 shipping isnt that bad. does anyone have comments or suggestions on these springs/retainers?
eh2_Trav
Engine Machining & Assembly
11-20-2016 11:47 AM
Skunk3
07-23-2009 04:32 AM
pchan
01-04-2007 09:57 PM
ek2k
04-11-2005 02:53 PM
