Brakes makin a weird noise :-\
My brakes make a weird noise... When i first bought the car about a month ago the brakes made a weird noise.. so i bought new brakes and i put the lubricant that came with it... it stop makin the noise for a while... then its back DUN DUN DUN!!!! HELP!!! do the rotors need to be resurfaced???????????
Re: Brakes makin a weird noise :-\ (Ecskater1313)
if your del sol is a d16 you should check and see if you bought ABS compatible brake pads. if you didnt buy those then the pads would be worn down again. as for the rotors check and see if you see any rust, scorched, or welted areas on the surface. i just got aem brakes....i know
