injectors and trotte body's
Hi All,
I was just wondering if there would be any difference good or bad if i swapped the injectors from my 1.5 civic vti for a set of H22a injectors??
Also would swapping trottle body's with the H22a one make any difference??
Thanks people
Thanks people
Re: injectors and trotte body's (snoopdogg)
the h22a throttle body is 60mm so it is an improvment, but unless you have a port match IM i doubt you will se much, and on the injectors, i know some of the prelude injectors are a different type then B an D series injectors, i think you can easily convert them but not sure, and im not 100% but i do think that they are alittle bigger then the D series injectors, but its not gona help you unless you have other significant mods and dyno time
Turbohatch
10-03-2001 10:36 AM
