Sluggish....then power
I was just looking for some opinions on what the problem may be. I have a 94 civic ex and a few weeks ago I blew the main relay plus the distributor was bad. So. I purchased a used distributor, looks good and had low miles on it, and got a new relay plus put in some new plugs. They are NGK 1095s. They are one range colder then stock. OK now for the problem. I put the car in first and hit the gas and the car slugs. It feels bogged down till the rpms rise up then it takes off. Then when I shift to secound it does the same thing. Real sluggish then back to normal. Should I go back to stock plugs? Could I be misfiring? Any help is very much appriciated.
Re: Sluggish....then power (94civicNewbie)
Look over the IM and see if theres any hose's lose or coming lose. Atleast thats my guess because thats what happened to me.
Could also be your spark plugs, what are they gapped to?
What motor? and i would try .040-.044 (not saying thats right or wrong but thats what i use and i dont have a problem).
Re: Sluggish....then power (Luserkid)
Its a D16Z6. Its my Honda learning engine. Gotta start somewhere right? Newbie question but, what does a bigger gap do vs a smaller gap? Thanks
My car has same problem. I think my car might have vacuum leak. But I don't know how to check that. Could you guys help me out.
thanks
thanks
Re: Sluggish....then power (Jaydeep)
Did you get the timing after you put on the new dist.? it sounds like it could be timing especailly if you changed the dizzy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicNewbie »</TD></TR><TR><TD CLASS="quote">So just adjust the timing belt normaly? And check for vacuum leaks. Anything else I could try? Thanks for all the help.</TD></TR></TABLE>
adjust the timing you'll be fine from there
Re: Sluggish....then power (ReDRoCkEt)
id also say its the timing.. a few friends have had the same problem.. maybe when your distributor was bad it caused the timing belt to jump a tooth... check that out.. hope that helps..
you can spray starting fluid around your hoses to check for a vac. leak. Don't go crazy on the spray and it'll be safe. If the car idle never moves during this, then it's a good sign of no vac leaks.
jchung
26
03-16-2007 11:24 PM
JDM_SOHC
26
06-28-2006 11:55 AM
