Map Sensor
Map Sensor?
I'm having trouble with starting my car right after i've driven it. I was thinking that it could be the map sensor. I've had the head replaced recently due to broken intake valves... could it be the map sensor?
BTW : The car consumes quite a bit more fuel than usual and the exhaust fumes smells like "unburned" gas so something is not mixing right... any ideas on what it could be or if it is even the sensor?
check ur code's
i burned my map sensor when i had a nitrous backfire 2 weeks ago car ran like **** retard timing relaly rich replaced it problem solved
i htink it is code 3
