Waterpump decided to go....
My waterpump went after my father put some radiator flush in it to "flush" the system. In a couple of weeks i will be doing and LS swap (buying the parts right now) so im not going to change the waterpump on the stock VX motor.
Question
Can i just put silicone or something all over it in the meantime to it doesnt leak? Im not going to use the car everyday...
TIA
Question
TIA
MEAT PATTY
Re: (B16EH2)
My water pump is leaking also, its leaking out of the weep hole. And it sucks because the coolant is getting on my timing belt and making it squeal like a pig. But I just ordered the whole kit from prostreet. I don't think silicone is going to work, but I guess it worth a try. If you do it make sure you let it sit over night and dry.
Re: Waterpump decided to go.... (Andres-eh2)
Doubt it dude. Silicone won't hold up. If it's pissing out of the weep hole and you're not going to drive it every day, carry a jug or two of water with you and don't go on any long voyages. You'll probably be able to sneak around OK, I have gotten away with it.
It depends on how bad it is. I've taken a water pump out of my Civic with a shattered impeller that was in 6 pieces.
Re: Waterpump decided to go.... (Debaser)
just carry a lot of water with u and never open the cap when it is hot (u probably already know that one) just reminding u
klion22
05-27-2008 12:28 PM
DRKSol
07-06-2003 10:52 PM
