TPS
Old 09-16-2004, 04:54 PM
kihun_cha's Avatar
Default TPS
is there anyway that tps can go wrong and make my idle go nuts?
is it because of dirts that gets in or what? can i fix it?
it seems to be like my idle is tps problem...
please give me some information to fix this problem
thanks you
kihun_cha is offline
Old 09-16-2004, 04:57 PM
2lua's Avatar
Default Re: TPS (kihun_cha)
need more info on your car. is the car surging? low idle, high idle? stumble?
2lua is offline
Old 09-16-2004, 04:59 PM
kihun_cha's Avatar
my car usally idles at 1300k that's how i always ran with my mods..
well past 5 weeks my idle has been going up and down insanely..
right now it's at 1500k and it's up and down from 1200k to 1600k sometimes to 2100k
Old 09-16-2004, 05:03 PM
McNizzle's Avatar
Default Re: (kihun_cha)
bump for answers.....i believe i have been having the same problem with my car as well. i have surging idle from 1000 - 1300 once my car warms up but ive already replaced the IACV, messed with the FITV and checked the throttle cables & vaccum lines.
McNizzle is offline
Old 09-16-2004, 05:09 PM
kihun_cha's Avatar
how do you check vaccum lines properly?
also when i took TPS out i kind of turned it on to right side and it seems to idle fine.. i think my problem is TPS
Old 09-16-2004, 05:12 PM
2lua's Avatar
Default Re: (Chris M)
check for air bubbles in the coolant system, iac and fitv again. when your car surge unplug the iac plug what happened to the idle? is the surge stop?clean out your iac, and the fitv. besure that the ring inside the fitv is screw in all the way.
2lua is offline
Old 09-16-2004, 05:14 PM
McNizzle's Avatar
Default Re: (2lua)
i have no bubbles in the coolant system, ive disconnected, cleaned and unplugged the iacv, made sure the plunger was screwed in all of the way on the FITV and it still surges after the car warms up
McNizzle is offline
Old 09-16-2004, 05:17 PM
2lua's Avatar
check for vacuum leaks. i read your sig. and you are using the chipped p28. try to swap out the ecu with a stock one. cause you had tried everything like you said. cause one of my friend swap out a stock ecu with a chipped one and his car had surge and throwing cel. come to find out his ecu missing an eprom.
Modified by 2lua at 6:31 PM 9/16/2004
2lua is offline
Old 09-16-2004, 05:33 PM
kihun_cha's Avatar
what do you mean unplug it? IACV? what is IAC ?
Old 09-16-2004, 05:34 PM
2lua's Avatar
iacv = idle air control valve. located behind the intake manifold.
2lua is offline
Old 09-16-2004, 06:02 PM
kihun_cha's Avatar
so just unplug it? by the way about fitv...
i took it out and when i try to put it bak in.. the screws even if i turned all the way right it wasn't ending and now when i start engine the coolant fluid comes out from there. damn it
is there something wrong with the screw?
Old 09-16-2004, 06:13 PM
2lua's Avatar
you might want to look at this post.
https://honda-tech.com/zerothread?id=858155
did you check for bubbles in your coolant system? you might want to bleed your coolant system. when you unplug the sensor the ilde should go to normal, if it does that then your sensor is fine. if it still surge then your sensor is bad. when you remove the iac did you clean it? did you put the gasket back? did you cross thread the bolts?
2lua is offline
Old 09-16-2004, 06:20 PM
kihun_cha's Avatar
this is what i did...
put more coolant since it was almost empty
took out eacv and i cleaned all the carbs
took out FITV and cleaned it but when i put it back in i couldnt screw all the way in because even if i did it kept on going and going..
where is the TCP on that diagramh?
Old 09-16-2004, 06:28 PM
2lua's Avatar
are you talking about the tps? did you do this to the fitv?
https://honda-tech.com/zerothread?id=699787
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kihun_cha &raquo;</TD></TR><TR><TD CLASS="quote">this is what i did...
where is the TCP on that diagramh?</TD></TR></TABLE>
you could have cross threaded the botls.
2lua is offline
Old 09-16-2004, 06:37 PM
kihun_cha's Avatar
mine is not like that
i have BBK Throttle body and Skunk2 manifold.. do you kno where TPS located on mine? and does it look same as that picture on b -series motors?
Old 09-16-2004, 06:42 PM
2lua's Avatar
it should be on the opposite side of the throttle cable.
2lua is offline
Old 09-16-2004, 07:01 PM
kihun_cha's Avatar
so basically u are saying that all TPS looks the same right?
Old 09-16-2004, 07:55 PM
kihun_cha's Avatar
isnt this tps?
Old 09-16-2004, 09:08 PM
McNizzle's Avatar
Default Re: (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">check for vacuum leaks. i read your sig. and you are using the chipped p28. try to swap out the ecu with a stock one. cause you had tried everything like you said. cause one of my friend swap out a stock ecu with a chipped one and his car had surge and throwing cel. come to find out his ecu missing an eprom.
Modified by 2lua at 6:31 PM 9/16/2004</TD></TR></TABLE>
no vaccum leaks. it shouldnt be the ecu though bc i ran that in my old car with the same set up with no problems. i dont have the stock ecu anymore to try, but i have reset the ecu and i dont know what else it could be, other than tps???
McNizzle is offline
Old 09-17-2004, 08:01 AM
kihun_cha's Avatar
my FITV does not look like that in the picture.. do i use different FITV if i have BBK TB?
and you kno how there is two holes inside the throttle? and the upper one is for IACV and the bottom one is for FITV? when i blocked the top one.. the idle went down and it guess it was on the normal idle.. is that mean my IACV is bad?
Modified by kihun_cha at 9:12 AM 9/17/2004
Old 09-17-2004, 03:18 PM
kihun_cha's Avatar
BUMP
dc97
11-08-2012 01:49 PM
deb1991
08-14-2011 11:03 AM
toyzbus
03-15-2005 11:55 AM
TheIntegraGuy
01-22-2004 06:48 PM
diLUDEd
08-22-2002 10:08 PM
Quick Reply: TPS
  • Ask a Question
Question Title:
Description:
