OBD0 b16a swap into 96 Civic SOHC VTEC ?'s
Old 09-17-2004, 05:14 AM
spcrxracer's Avatar
Default OBD0 b16a swap into 96 Civic SOHC VTEC ?'s
ok here's my question. I am going to be swapping a first gen obd0 b16a into a 96 sohc vtec civic. Should i buy OBD2 ecu so it plugs into the 96 civic harness and wire it up obd2, or just buy obd1 ecu and jumper and wire up obd1. it already has vtec components wired up so which should i do?? any advice will help. THANKS!!!!!
EDIT: also if i go obd2 can i use the sohc distributor or do i need b series OBDx distributor?
spcrxracer is offline
Old 09-17-2004, 11:23 AM
spcrxracer's Avatar
Default Re: OBD0 b16a swap into 96 Civic SOHC VTEC ?'s (spcrxracer)
bump
Old 09-17-2004, 11:32 AM
Moderator
chad's Avatar
dude....you are soooo up a creek if you are asking these questions!!!!!!!
you have no idea!!!!
search....
basically you need to convert the NONOBD engine to obd2....meaning
dizzy
crank angle
obd2 oil pump
obd2 tbelt cover
obd2 injectors
then you'll need a chipped p28
obd2a to obd1 jumper harness
do i need to go on??
pay someone who knows what they are doing!!
chad is offline
da_rimrocka
06-09-2006 11:36 AM
Cractos
07-26-2005 10:46 PM
FritzInTN
03-08-2004 11:39 PM
FritzInTN
01-19-2004 03:51 PM
2trix
04-11-2003 09:11 AM
Quick Reply: OBD0 b16a swap into 96 Civic SOHC VTEC ?'s
  • Ask a Question
Question Title:
Description:
