B16A Direct From JAPAN to a 2000 CIVIC needs help ASAP!!!
Old 09-17-2004, 01:04 AM
aLLm0t0r's Avatar
Default B16A VTEC w/5 spd hydralic tranny Direct From JAPAN to a 2000 CIVIC needs help ASAP!!!
Hello,
I have a B16A plug and play/complete swap for my CIVIC '00, but I'm having problem with the wire harness, Can I use my stock ECU?since it's OBD II and the wiring is only one piece or put the wire wire harness that came in with the motor and buy a adapter for the engine harness to connect to the ECU? Will my ECU even work for the B16A ?
2000 honda CIVIC HX 2 DOOR / OBD II wireharness
big plug GRAY with white strip - BLUE plug with white strip - small plug GRAY with white strip ...this connects to the ECU
THANKS...
Modified by aLLm0t0r at 2:18 AM 9/17/2004
Modified by aLLm0t0r at 2:20 AM 9/17/2004
aLLm0t0r is offline
Old 09-17-2004, 01:08 AM
Default Re: B16A Direct From JAPAN to a 2000 CIVIC needs help ASAP!!! (aLLm0t0r)
tell the nice people here more info...
what trim of 00 civic, what gen B16a?, grey or white plug... yata yata
ARIZONA is offline
Old 09-17-2004, 01:52 AM
aLLm0t0r's Avatar
Default Re: B16A Direct From JAPAN to a 2000 CIVIC needs help ASAP!!! (ARIZONA)
B16A VTEC w/5 spd hydralic tranny Direct From JAPAN to a 2000 CIVIC HX
THANKS...
aLLm0t0r is offline
Old 09-17-2004, 02:38 AM
Nameless RB26's Avatar
I don't believe that harness will work with your car.
From what I remember, you'll need a harness with 2 ecu plugs. 96-98 had three ECU plugs and 99-00 had two.
A 99-00 Civic Si harness would likely solve all your problems.
EDIT: you'll need to use a 99/00 Si ECU with that too. If you don't want secondary 02 sensor problems then you'll need to wire that correctly or convert to OBD1.
I'd personally convert to OBD1.
Nameless RB26 is offline
Old 09-17-2004, 05:11 AM
tallblondkid's Avatar
Default Re: B16A Direct From JAPAN to a 2000 CIVIC needs help ASAP!!! (Nameless RB26)
u need a conversion harness, that motor is OBD1 and urs is obd2, ebay has them for cheap
tallblondkid is offline
95 integra
Honda S2000
09-07-2012 12:52 PM
RB_EJ8
07-17-2008 10:38 PM
jay-d-em
03-10-2008 01:14 PM
TheHatchHog
05-08-2003 02:49 PM
1.8EG-T
03-18-2002 03:42 PM
Quick Reply: B16A Direct From JAPAN to a 2000 CIVIC needs help ASAP!!!
  • Ask a Question
Question Title:
Description:
