Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page >
Whats the easiest way to change the passenger side parking light on a 99 si?
Old 09-17-2004, 05:54 AM
breathinez's Avatar
Default Whats the easiest way to change the passenger side parking light on a 99 si?
This is my girls car and I need to change her parking light on the passenger side. But it looks like you have to take the dang bumper off. I started to take the headlight out by removing the two 10 mm bolts on the top of the headlight but it wouldn't move, and I didn't want to force it. I'm not an idiot but there has to be an easier way. Oh and already did a search and looked in the faq but didn't come up with what I needed.
breathinez is offline
Old 09-17-2004, 06:09 AM
gftgrill's Avatar
Default Re: Whats the easiest way to change the passenger side parking light on a 99 si? (breathinez)
read the owners manual. either take off the bumper and remove the headlight. there are 4 10mm bolts holding it in. or turn the wheel all the way in, and pull back the fender lining and reach in. if you have big or fat arms, I would reccommend removing the bumper. I have long thin arms, so it's no problem for me to reach through the fender well.
good luck
gftgrill is offline
Old 09-17-2004, 06:13 AM
VinceVTEC's Avatar
Default Re: Whats the easiest way to change the passenger side parking light on a 99 si? (gftgrill)
take the bumper cover off and take out the headlight. That is the easiest way.
VinceVTEC is offline
Old 09-17-2004, 06:28 AM
AutoXer's Avatar
Default Re: Whats the easiest way to change the passenger side parking light on a 99 si? (VinceVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VinceVTEC &raquo;</TD></TR><TR><TD CLASS="quote">take the bumper cover off and take out the headlight. That is the easiest way.</TD></TR></TABLE>
Yeah, the bumper is only the 4 rivets on the top of the grille, two screws on the bottom, and two in the fender. It only takes about a minute or so once you know how to do it.
AutoXer is offline
Old 09-17-2004, 06:38 AM
sonic em1's Avatar
Yeah, remove the bumper. Takes 5 minutes and will make it easier. There are 4 10mm bolts that hold the headlight on. 2 top, 2 bottom. Then just twist out the bulbs.
Good luck
sonic em1 is offline
Old 09-17-2004, 08:06 AM
breathinez's Avatar
Default Re: Whats the easiest way to change the passenger side parking light on a 99 si? (sonic em1)
Thats what i thought....Smart engineers in Japan make a car where you have to remove the damn bumper to change a damn parking light.
Old 09-17-2004, 08:10 AM
wizardboy's Avatar
if you mean parking light bulb or turn signnal bulb loosen the fender well lining to access the bulb it is easy they wouldnt make u remove the assembly to change the bulb reach in and turn it to the left and replace bulb
wizardboy is offline
Old 09-17-2004, 08:12 AM
Ricey McRicerton's Avatar
Default Re: Whats the easiest way to change the passenger side parking light on a 99 si? (wizardboy)
Just so you know, my Civic is BY FAR the easiest to work on car I've ever messed with. Taking off the bumper takes 5 seconds.
Ricey McRicerton is offline
Old 09-17-2004, 08:26 AM
dantastic's Avatar
umm to change the blinker/marker light bulb, you just peel back the fender liner. no need to remove the headlight or bumper.....
dantastic is offline
csc67
13
11-05-2015 04:11 PM
RapeV-8
12-19-2010 04:21 PM
jk7701
06-07-2010 05:10 PM
hermtm2
Honda Civic (2006 - 2015)
16
10-16-2009 12:13 PM
dLo GSR-stolen-now-WRX
05-20-2002 08:51 AM
Quick Reply: Whats the easiest way to change the passenger side parking light on a 99 si?
  • Ask a Question
Question Title:
Description:
