horn doesnt honk!!!!
i have a 92 civic cx, and my honk doesnt work. i was hoping you guys could help me out, i have no clue where to start looking so any advice would be great!
Re: horn doesnt honk!!!! (b16a93cx)
Is your srs light on? Cause if it is it is most likely your cable reel. They are on the same relay and I have the same problem as you.
My horn didn't work either but I could hear the clicking noise from the relay. It turned out it was the wiring to the horn itself had coroded. I just needed to cut the first six inches and hook up new wires.
HT Black Ops
Re: (ironcheftony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony »</TD></TR><TR><TD CLASS="quote">check the horn fuse ?
under teh dash i think</TD></TR></TABLE> the horn fuse Is under the hood in your engines fures box 20amp fuse should be yellow, if that fuse is blown your brake lights will also not work...
put power straight from your battery to the horn if it doesnt work, bad horn. work your way back from there for power to ground causing a short. if you have to pass inspection or something wire it to your own swith to bypass all your other possible bad connections.
it is possible it might be the horn relay which in on the upper right side of the under dash fuse box. I dont remember the color of the wire off the top of my head, but if you ground one of them, the horn should work. Gt a test light and check it out. I tore my cable reel accidentally and my horn stopped working. I had another cable reel sitting around and popped it in and I have my horn back.
Re: (MichaelJComputer)
I have one of this big loud, I think they are air horns in my ride. I hated the weak sound of the stockers. It's also pretty easy to wire up your horn.
r1de4life
05-03-2006 07:29 PM
