RSR Exmag II wont fit VX eg?
Old 09-16-2004, 04:45 PM
GAccord's Avatar
Default RSR Exmag II wont fit VX eg?
Whats up with that? Is the exhaust position different between models?
GAccord is offline
Old 09-16-2004, 04:48 PM
ej1 pilot's Avatar
Default Re: RSR Exmag II wont fit VX eg? (GAccord)
yes on the vx the cat converter is on the exhaust manifold so the setup is different, to bolt up the exhaust you need an si or dx header and a new cat
ej1 pilot is offline
Old 09-16-2004, 06:01 PM
GAccord's Avatar
Default Re: RSR Exmag II wont fit VX eg? (Art In Motion)
So since I'm putting a h22 into it, it doesnt matter and it will fit then?
GAccord is offline
Old 09-16-2004, 06:05 PM
slammed_93_hatch's Avatar
should be close to fitting. it might need to be trimed down alil. contact JDMlifrstyles about his exhaust
note this exhaust DOES NOT use a cat
slammed_93_hatch is offline
Old 09-16-2004, 06:13 PM
CivicVX94's Avatar
Default Re: RSR Exmag II wont fit VX eg? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">should be close to fitting. it might need to be trimed down alil.
No dude it will come NO where close to fitting and unless you want to replace your stock header and cat, from any D-series engine from 92-00 other than CX or HX basically, (or an aftermarket header and cat for that matter), it requires a lot of fabrication for it to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by art in motion &raquo;</TD></TR><TR><TD CLASS="quote">
yeah....kinda. The cat is directly under the exhaust manifold, opossed to under the car like most other models, but not literally on it. And you don't need a new cat, you could use the header and cat from, well see ^. The vx cat MIGHT work, I'm not sure. I think they are the same but i'm not sure. But for sure you'll need a new exhaust manifold (or header) or a lot of fab.
CivicVX94 is offline
Old 09-16-2004, 06:18 PM
GAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">should be close to fitting. it might need to be trimed down alil. contact JDMlifrstyles about his exhaust
Yea, he's running a b16 so it doesnt matter really.
Bottom line, will this exhaust work with a h22? Yes or no?
GAccord is offline
Old 09-16-2004, 08:17 PM
GAccord's Avatar
TTT
GAccord is offline
Old 09-16-2004, 08:34 PM
yes
you might need an extension or shorting of the tubbing but it will work
jonnybadboi9
05-01-2007 05:56 PM
xelloss
07-26-2006 12:07 PM
sik94hatch
04-05-2006 12:50 PM
Nooch
08-28-2004 12:00 AM
BlackAC99
11-14-2002 09:00 AM
Quick Reply: RSR Exmag II wont fit VX eg?
  • Ask a Question
Question Title:
Description:
