can u use a big c clap to press your caliper piston
Old 09-17-2004, 05:14 PM
ricekiller's Avatar
Default can u use a big c clap to press your caliper piston
a kid in my auto class was sayin, he press his pistons with a big c clap. Is it possible to do that, is the c clap strong enough to press the piston in. Just wanted to know cause i never try this method before. I only use the block and fast bac tool. any comments appreicated
Old 09-17-2004, 05:20 PM
nocturnaldragon's Avatar
Default Re: can u use a big c clap to press your caliper piston (ricekiller)
Of course, unless your pressing on the pedal at the same time there next to no resistance you can almost use your hand to push it in so, Now that only works on front pads not rear disk, you need to twist those as you press them in due to the parking brake issue.....
Old 09-17-2004, 05:21 PM
jdm169's Avatar
i use a c clamp and a small block of wood, doesn't really take that much effort
Old 09-17-2004, 05:24 PM
hayabusa160's Avatar
Default Re: can u use a big c clap to press your caliper piston (jdm169)
i used a c clamp and the old brake pad to push them back in
Old 09-17-2004, 05:26 PM
second edition's Avatar
Default Re: can u use a big c clap to press your caliper piston (hayabusa160)
c clamp here as well.i didnt know people did it any other way.
Old 09-17-2004, 05:30 PM
civic_tuner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">i used a c clamp and the old brake pad to push them back in</TD></TR></TABLE>
Old 09-17-2004, 05:33 PM
Plan B's Avatar
vtec69's Avatar
i have always used a c-clamp with the old brake pads and never had a problem doing that
Old 09-17-2004, 05:37 PM
murtnabila's Avatar
Default Re: can u use a big c clap to press your caliper piston (vtec69)
A pry bar is quicker/easier IMO. I use that with the old pad still in place.
Old 09-17-2004, 05:48 PM
88hondahatch's Avatar
yep c-clamp here as well
Old 09-17-2004, 07:09 PM
t0p_sh0tta's Avatar
Default Re: can u use a big c clap to press your caliper piston (murtnabila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila &raquo;</TD></TR><TR><TD CLASS="quote">A pry bar is quicker/easier IMO. I use that with the old pad still in place.</TD></TR></TABLE>
Old 09-17-2004, 07:13 PM
slambedcivic's Avatar
Default Re: can u use a big c clap to press your caliper piston (t0p_sh0tta)
i use a pair of pliers and the old pad.... when a c clamp or a caliper spreader isnt availble.
Old 09-19-2004, 04:57 AM
Charbon Sty's Avatar
Old 09-19-2004, 05:09 AM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm169 &raquo;</TD></TR><TR><TD CLASS="quote">i use a c clamp and a small block of wood, doesn't really take that much effort</TD></TR></TABLE>
Same here.
Are we seeing a repetitive theme here yet?
Old 09-19-2004, 06:29 AM
sk8rmike's Avatar
Default Re: can u use a big c clap to press your caliper piston (INVALID)
chan locks = 10x better/faster than a C clamp though...
Old 09-19-2004, 08:09 AM
But with the pry bar theres an increased chance over the C-Clap that youll push the piston in wrong and freeze the caliper. More then likely not to happen but theres still a strong chance so i just use the ol C-Clamp methode.....
Old 09-19-2004, 08:14 AM
SOHC_MShue's Avatar
Default Re: can u use a big c clap to press your caliper piston (nocternaldragon)
I use the c clamp here
hodsintegra23
04-06-2022 11:12 AM
georgiajdm
02-24-2008 02:14 PM
rasinhell
12-02-2007 03:33 PM
ITR198
11-05-2005 08:25 PM
freeway
06-07-2005 08:55 AM
Quick Reply: can u use a big c clap to press your caliper piston
