Fuel Pressure Question
Old 09-16-2004, 08:17 PM
DelSolKid's Avatar
Default Fuel Pressure Question
How many pounds should I run my fuel pressure at on my 1994 JDM B16a DOHC VTEC Motor. It has Skunk 2 cam's, AEM cam gears, Fluidyne Radiator, full intake upgrade, full performance exhaust, AEM Adjustable FPR, Competition Fuel rail, Nology Plugs and a custom chipped ecu with VTEC Crossover set at 5400 and Rev Limit at 9000.
Thanks in advance
DelSolKid is offline
Old 09-16-2004, 08:22 PM
All Motor Mentor
00Red_SiR's Avatar
Default Re: Fuel Pressure Question (DelSolKid)
I would set it to the stock fuel pressure settings 38-40psi I believe and leave it till you can check it on a dyno. Chipped ecu's tend to run a little rich as it is so adding more fuel isn't going to help. You need to see what your air fuel ratio looks like before you make any adjustments over stock settings.
00Red_SiR is offline
Old 09-16-2004, 08:32 PM
DelSolKid's Avatar
Default Re: Fuel Pressure Question (00Red_SiR)
I had my chip set to stock fuel ignition tables before the vtec crossover, and aggressive ones after it. I used to run to rich before the crossover but now I think it's fine, I just want to make sure it has all the fuel it needs for after the crossover, soon I'll be changing the chip to slightly more aggressive fuel ignition tables before the crossover, stock sux. Anywayz, what would you reccomend then, still the same?
Old 09-16-2004, 08:53 PM
All Motor Mentor
00Red_SiR's Avatar
yes I would...always start out with the stock settings and then check the car out on a dyno to see how the air/fuel curve looks. That's the only real way to determine wen and how much the fuel settings should be changed for maximum power and reliability. If not you're just guessing and bad things can happen.
Old 09-16-2004, 08:56 PM
DelSolKid's Avatar
Thx for the Info
Freemananana
02-22-2014 03:40 PM
x_doug-x
01-30-2011 02:10 PM
SHystrdyGSRtdy
02-23-2005 10:23 PM
vtecjb
07-03-2003 11:52 PM
spun Vtec
11-07-2002 09:27 AM
Quick Reply: Fuel Pressure Question
  • Ask a Question
Question Title:
Description:
