noise from lowering springs?
i just put my lowering springs on about 2 days ago and they are makin a noise when i turn the wheels. i check to see if maybe the tires were scrubbin but they aren't . is that noise just the springs settling in or could be something else? thanks for your input.
Re: noise from lowering springs? (Targa250R)
it sounds like a clunk or poppin noise coming from where the springs are and i think its just the springs being warn in but i just wanna make sure if im right or not
Re: noise from lowering springs? (mugenman20)
make sure everything is tight!!! that happened to me also. I heard it on the passenger side only so i was like WTF!!?? and it turned out to be the lug nuts weren't tightend down good and my wheel was moving around
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenman20 »</TD></TR><TR><TD CLASS="quote">it sounds like a clunk or poppin noise coming from where the springs are and i think its just the springs being warn in but i just wanna make sure if im right or not</TD></TR></TABLE>
Noises are definitely not normal with lowering springs. As mentioned, check to make sure everything is tightened properly. Also check to see if your tires are hitting anything when you turn the wheel. What springs did you use?
The noise only happens while turning, not while going over bumps?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
The noise only happens while turning, not while going over bumps?</TD></TR></TABLE>
Hmmm... I do not agree to some point...
Yes, the noise is not normal, but it is not abnormal either...
The new springs must settle in and that produces noises...
I.E. when turning, going over a bump and so on...
Give it a few days BUT DRIVE CAREFULLY...
Before you drive, check that everything is tightened properly and that everything is seating where it should...
It should settle in 6-7 days of driving... if it doesn't then check for problems...
PhuCDatBiCh
06-25-2008 10:57 AM
ClownRider
06-16-2002 07:10 PM
