View Full Version : Honda CRX / EF Civic (1988 - 1991)
- MD, CRX Build Thread
- 1990 Civic w/ D16Z6 - alternator replacement
- Apexi N1's 241-H008 Rear Coilovers
- What half shalt and axles should I use?
- eBay radiator
- clarification on options for my project.
- lower ball joint problem
- Transmission bracket ripped from frame
- 88 CRX Si Cranks But Won't Start
- My d16y7 bad idle
- 91 door mirror what works
- Rod bearing question
- help with crx
- 89' hatch swap from auto to manual
- 1991 CRX Headlight Issue (low beams went out and highs beams 10 seconds later)
- Is this 1990 CRX worth the $
- 91 CRX OBD-0 OBD-1 Swap. Starts Runs 30 Seconds Shuts Off
- Cable to hydraulic conversion D16Z6
- MPFI swap, tandem control valve
- Oil in Spark Plug Tube
- tranny swap help
- need help with VSS!
- 88 civic si hesitating
- Std 4speed to si 5speed swap
- Rocker arm tapping
- Push to start button linked to starting problem?
- 1991 RT4WD Wagovan Restoration/Build Blog Video/Pics!
- 90 DX Hatchback B16a daily build
- Getting my ED7 BAR'D, What will Work??
- Coilovers???
- Cap and rotor condition
- SOHC mechanical timing
- Looking @ buying a 1991 CRX-HF
- Recommendations/ Advice
- CRX VIN identification
- My crx zc swap
- Quick advise on rebuilding my B16 Block
- JDM Adjustable Fuel Pressure Regulator
- old project that has returned to me
- Just because im bored and got two free cars
- IACV for ZC
- 91 civic fuel issue
- 91 Std Z6 swap Need little help
- Potential first Honda purchase...advice appreciated
- DX to HF... prepare to flame
- Cooper works rotors + dc5 calipers on ef axels
- fuel problem car not runnig right.
- My new 1989 CRX Si
- 89 civic si b20b need AC!!
- Vtec problem, CEL 21. D15b2 with z6.
- CRX idle issue with AC running
- GSR swapped 1990 Si coding CEL #9
- Can't retard timing any further 91 Civic DPFI
- problem mpfi swap
- My ef
- hole in radiator cap
- Leaking/stuck injectors and bad timeing?
- How Light is your EF?
- 89 crx hf dohc zc swap electrical issue
- anyone see a pattern with this bad luck
- jdm b20b civic wagon dyno
- Squealing drum brakes
- Starter probz
- Swap into a CRX need some assistance
- ED7 Si Build up
- 1991 EF Sedan DX w/ EG Axles hub not spinning
- Still rolling stock height.
- 1990 Honda crx break problem I think..
- DPFI Running rich
- 89 Civic si steering wheel removal
- 91 civic si bogs down when shifting
- need help with a door guide bolts
- 91 Civic DPFI - Tries to stall when braking
- Limp mode??
- Passing emissions issues
- 1990 Civic Si tach not working correctly
- Car wont start after switching ECU?
- Brian_EE4's RT4WD Wagon Build (Picture HEAVY)
- Loose Clutch Spring Rattle????
- Do Auto pm6 ecus exist?
- Buying a 1990 crx - need advice
- windshield sprayers inop
- Neutral Above Idle Fluctuation/Occilation
- brake shoes on efs?
- Here I go again.. #3 1990 si mint! k20 turbo swap.
- RSX leather REAR SEATS in my 88' CRX
- Zc = 1.5l?
- cant find the head code for a pm3-16
- Mini-me Motor mount issue?
- Ok i need some help with my swap
- No drive over 1,000 RPM and oil leak
- 1990 EF hatch, D15B1 DPFI issues after oil change
- Need Help Diagnosing EF w/ D16A6
- 89 crx si B16a crank no start
- No rev past 3k?
- 1991 Wagovan A/C Issues
- upper control arms hit
- 1991 Accord rough idle and more with AC on
- An ignition timing mystery...
- help!!! trying to know the probem why its shutting off
- please help!!!!
- 89 CRX DX Blower Problem
- Help!! 88 crx bluish smoke under load car has been sitting
- HELP!!! B18A1 in a 1990 CRX HF D16a6 SWAP
- Please Help
- 1991 Civic Dx Crank, no start problem
- Help a newbie find resources/info?
- Problems swapping 91 HF cluster into 90 DX
- Questions about EF B Series Mounts
- essentials to convert obd0 to obd1/2
- information for my B16A
- Squealing - what is this
- OBD0 to OBD2 wiring
- wiring guru needed 91 dx lsvtec I took a big bite..
- where to find "SI" badge
- B16A1 - What is officially the number of O2 sensors
- need help can i use an obd2. motor
- Wiring disaster
- Long term qsd steering rack effects
- just another lsvtech build. (frank-N-Bolts)
- B16a sir crx no spark
- Sunday driver.
- New to the forum and looking for a CRX
- windows trims for EX SADAN 1990
- Clutch questions
- b16a with pwo into 90 si,pre-detonation need help
- 91 civic dx/B18a1 build - Any tips?
- 87 CRX SI A/C Help Needed
- Climate Control Problem???
- 91 civic wagon no start no cel
- 91 civic wagon K20A Type R swapped
- Blind luck Floor Mat purchase
- name there plugs
- My Honda is back on the road.
- Skunk 2 Short shifter with hasport linkage question
- interchangeable brake rotors 89'/90'
- Skunk2 Pro series intake manifold on d16a6
- fuel pump / and 2 plugs i dont know what there for
- Just picked up a 91 Civic. Can anyone please help me with the purpose of this mod?
- 8th generation Si seats in a Civic EF Hatch
- CEL stays on after 2 seconds but no led light
- Stutter under 2k RPMs
- mini stock car
- EF.IT.UP 's 88 Krx Build (slow)
- 90 Civic Hatch bumper on a 91 CRX
- Wheel Supreme DS-14
- Cel on b16a swap
- 88 cluster noise
- Trying to figure out the best option
- A6 Cam
- car violently shakes at 30 mph and over
- Recommened repair manual questions
- 90 hatchback stopped running
- Need help on idle and accel
- Wiring Diagram
- No start condition
- DOHC ZC swap no start
- z6 swap 91 crx si axles?
- Tanabe exhaust on b20
- Radius Rod -> LCA bolt. Anyone have trouble with it backing out?
- Help please Brake Caliper replacement
- CEL light turn off after 2 seconds when key in the on position
- Engine suddenly won't start
- how do you lube up a distributor ?
- d16a6 block possibly bad
- DOHC ZC HELP
- Cooling system problem
- Matsushita compressor clutch making rapid clacking noise
- 88 crx si E-brake cable question
- NEED HELP 89 Civic!!
- swap advice
- other similar relay for this one? (headlamp)
- Door Panel question
- distributor problem
- 89 ED3 restore/build with pics
- d16a6 oil light on at idle
- 90 civic truck
- Power Locks and Window Kit
- ED/EF with Hydro B-series Question, Need measurement
- 88 dx sedan manual swap
- kay's 91 ef hatch
- Battery light goes on when I turn off engine
- d16a6 tdc
- where does this wire go....b16 crx
- Electric load lowers idle, advances timing... this normal?
- Ax???
- 85 Crx bugging down
- What grounds do I check when my ECU says my ELD is bad?
- Code 1 problem
- 88 civic wagon, booster leak?
- d16a6 valve issue
- Window Reg 91 CRX si Summer time SOS!!!
- 90-93 Integra Coupe seats in a 90 EF Sedan
- Wire harness replacment
- d15b2 idle dip (not a surging or searching idle problem)
- Adding A/C to 90 civic
- Ef9 front conversion, where to buy nowadays?
- Ecu pin wont stay in
- My Rear Suspension Rebuild (pics)
- Drivetrain vibration at 3-4k & k shifting issues at 7-8.2k
- 87 Honda Civic Wagon Carb Stalls while driving
- 88 Civic Hatch Headlight and Cluster Light Problem
- ef SiR vs EG SiRII
- d16 block/d15b head help??
- Need some help. 89 CRX intermittent no start
- battery draining, please help!
- NEW DRIVER - HELP ME OUT
- Civic ef problem
- Ef hatch B18 A/c Help!!!!!!
- Civic wiring have extra plugs need help asap! Identify where its suppose to go Pics !
- installing 88-89 Prelude fogs on USDM Crx
- B16 Swap Problems
- 88 crx d16a6 motor help
- Ef hatch d16z6 swap
- DPFI vs Auto Trans??
- stalled out going 60 on hwy, made sputtering sounds, then won't start?
- --EDIT--
- Ef civic si sway bar sizes question
- $9 CAI '89 Hatch Civic
- A/C causes idle on cold engine to lag down and stall
- 15x10in on ef sedan
- Need discontinued part-Breather Assy Pipe
- 1990 Civic Si bogging problem
- damn alignment shop wants alot for an upper ball joint
- Honda crx d16z5 distributor
- b18c1 Post mount
- THE LUNCHBOX!
- 88 DX sedan B20 engine swap questions!
- I know this has been asked 1 million times but....
- ZC head on a D15B1
- Car battery problem?
- 89' Crx si build thread
- Code 1 02 Sensor issue
- EF7 CR-X Build looking for direction/ wisdom
- dpfi questions
- Few issues need some guidance/advice
- Help with installing EK and EG parts on crx
- conversions
- J-Power Civic Rear Camber Adjusters
- help can't find
- what rear calipers will fit 89 crx si
- Window Reg
- 91 ef hatch a/c help
- Cel 7 and 14 showing up at the same time.
- Source for new front hubs
- obd0 to obd1
- Possible fuel issue more insight needed!
- 91 civic hatch race project
- NGK Spark plugs, opinions?
