OBD0 to OBD2 wiring
Old Aug 9, 2015 | 04:04 PM
Wakeboarder482's Avatar
Default OBD0 to OBD2 wiring
I am doing a type r swap into my 91 si and was wondering if anyone had the schematics for the wiring.
Old Aug 9, 2015 | 04:40 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: OBD0 to OBD2 wiring
No diagram needed. Use an OBD0-2 ECU adapter, distributor adapter, alternator adapter, and injector adapter. You can then use a subharness to add VTEC, 4 wire 02, and knock sensor. Don't use a USDM ECU as you'll be chasing emissions code for the rest of your life. You could rewire all the above sensors as well but the adapters make it plug and play.
Old Aug 9, 2015 | 05:33 PM
crx_si-r's Avatar
keep it obd0 and get a chipped obd0 ecu. call it a day.
Old Aug 11, 2015 | 06:24 PM
v4lu3s's Avatar
RTFM
see my plan would be different than the above...
i would do an obd1 ecu and distributor, modify my stock harness to fit, run a hondata s300...
sort of like what i did with my high compression d16a6...running obd1 ecu, obd2 injectors, obd1 distributor and hondata s300
Old Aug 12, 2015 | 06:12 AM
crx_si-r's Avatar
no need to swap to an obd1 distributor if the swap already came with an obd2 distributor. both dizzy work fine with an obd1 ecu. ideally of course would be to use all the components that came with the itr swap and just use an obd1 ecu. it of couse all comes down to the op and what his plans are and if he is on a time crunch.
im running chipped p61, obd1 lsv with obd1 dizzy, obd2 itr injectors and obd1 b17 alternator.
Old Aug 22, 2015 | 02:40 PM
Matt8314's Avatar
Another option here is to use a 1997-1998 JDM P73 ECU. This ECU uses OBDII plugs, but basically runs like an OBDI ECU. In other words, it uses just a single oxygen sensor, no crankshaft speed fluctuation sensor, and no fuel tank sensor. Also, unlike USDM OBDI, there is no purge valve or VTEC pressure switch. You just modify your harness as you would for an OBDI ECU, and wire up the OBDII plugs, but without all the OBDII sensors. It's no harder than OBDI, and you get the right fuel maps right out of the box. And if your motor is JDM, you probably already have it.
civic-one
Jul 30, 2009 06:00 AM
fin781
Jan 19, 2007 09:16 PM
turbo77nyc
Sep 22, 2006 05:20 AM
turbo_civic_ek
Oct 28, 2004 02:16 AM
Norcalstoppy
Jul 13, 2002 08:02 AM
