- y8 intake manifold on a6
- Ls/B20 head
- crx front sway bar change
- dont start..HELP PLEASE
- 87 CRX Si not starting, backfiring
- MPFI mini-me conversion **UPDATE**
- Need help on fixing rims.
- help with b16
- where can i get oem swaybars at?
- DX wiring harness
- STRUT TOWER BAR QUESTION
- D15B1, and D15B2 pistons the same?
- crx console in hatch
- Differences between 88-91 crx fenders?
- 1st gear problem
- Din gauge pod?
- stolen crx in chicago!!! look out
- OMG CRX with Benz front end (possible repost)
- looking for usdm parts
- 2000 SI head distributor?
- ES Oval Muffler..
- Red ef in my neighboor hood, laurel md, you on honda-tech?
- retapping block?
- 1g crx mpfi?
- need quick ecu help.
- headlight bulbs...
- 90 Hatch RHD Conversion
- 5 lug type r swap. i tried searching
- Sleeve or not?
- one piece headlights
- short shifters...
- Power Windows
- CRX Exhaust question set up
- I have been hiding and collecting parts and need help!!!!!
- Trunk Audio Pics
- 88-91 Civic/CRX Traction Bars
- Oil disappearing!!
- MPFI Dizzy
- Ls/vtec or Ls turbo
- is it possible to weld a 2 and a half inch muffler to a 2 inch cat
- vtec controller making car bog!!!!
- does anyone on here make a cover that goes over existing climate control?
- anybody ever seen rust this bad?
- Greddy evolution exhaust on stock pipingon 1991 civic hatch?
- heater motor dead in ef..can i swap out for a..
- J TECH SUCKS
- alternator or battery?
- Fuel Management Turbo B16 CRX??? HELP 15-18 psi
- eh2 seats in ed6?
- power steering
- 450cc inj
- didnt pass smog help?
- which part do i use?
- d16a1 is gone wat next
- fourthgenhatchb17 i am really interested........
- How screwed am I?
- DA INTEGRA CLUSTER - CRX **SEARCHED**
- clutch squeek helllppppppppppp
- what all does it take to make a vtec head work on a crx
- 90 crx hf with d16y7. get a y8 or z6 head???? help!!!
- steering wheel ?
- Fastline Performance Road Race shifter
- Hydro tranny vs cable tranny.
- timing belt problem
- no heat no air coming out of the vents
- Can any one help mr out as to what years my motor is? (B18C1 obd1)
- my temp gauge is out?
- List of Successful Seat Pan Swaps
- crx animation?
- Decent turbo setup
- Ive got a 1stGenB16....
- Code 15 + Jumpy Tach + random stalling... :(
- 88 LCAs same as Type R? Please help!
- just bought a 91 civic hatchback and have a question :)
- CRX with B16 on PR3 What is your setup with Fuel pressure.
- couple questions on swap
- which motor??????
- Integra Radiator in a 89 CRX?
- Remember this picture?
- Another stupid bolt question
- new to the engine swap thing
- Civic EF2 Questions?? Can somebody help??
- 91 Crx Si Custom interior shift/e-brake console help please!!
- omni power coilover kit or groundcontrol coilover kit?
- 2005 CRX CONCEPT
- b16 mounts
- Hasport Sub-harness
- Exhaust
- mini me
- What year tranny?
- Is this a good deal?
- Gauge Pods
- does anyone know the part number for a aem filter short ram intake?
- 2 engine hatchback
- if i run obd0 for my gsr would it do any to the performance?
- look at this its crazy!!!!!
- My ride is SOOOO Firm.....wtf
- is cargo cover ...
- EK hatch lower tie bar into EF hatch
- X-mas wish list for crx
- Honda's cost saving features
- Looking for advice on buying an older civic
- Do I need these?
- CRX
- how to check CEL
- Fuel Pump in 1987 Civic Si Hatchback
- Got into an accident with my car (not my fault) need some advice...
- ZC Dohc Nitrous
- sounds from G1 B16 and 99-2000 B16. Why so different?
- Help WIth Z6 SWap PLZ!
- wats the difference from obd0 and obd1
- heat is not working
- B-series crx axle question..
- motor swap ecu question
- Quick Question
- question for sir front conversion.
- jdm crx front clip(brakes)
- **INTEGRA AXLES ON A CIVIC**
- Crx ee8 Vtec
- would it possible 2
- CTR, ITR, or aftermarket cams?
- Which JDM cable LSD trannies compatible with my 91 LS clutch and 90-93 axles?
- how to replace rubber tube in front brake line?
- Si Cluster problems...
- Axles differences
- Injector ?
- B16a Intake manifold question...need help.
- Looking for CRX
- rubbing noise, axle?
- Need Help With Buddies CRX
- does anyone have STOCK 88 HF qtr mile time?
- is this ok?
- random exhaust question
- Wilwood Big Brake Kit CRX
- How to find a CRX?
- for all the crx pros out there...Cam's
- Whats the Diameter of a Aem Short Ram Intake?
- can someone identify these corners?
- Dumb starter bolt up question.....
- *** What have u killed with your EF :P ***
- axles integra 94 and up with Ef
- The Seatbelt Recall :D :D
- 1990 honda civic hatch brakes
- i was wondering if i can use parts from my crx hf with si motor for my gsr swap
- ZC mounts the same as B-Series?
- B16A Piping
- E-Brake pops up.. light comes on, anyone else?
- 76" eb civic
- car wont start but it will
- 87 crx si monza exhaust sound good
- Car will NOT start - slowly died on the freeway...
- Short somewhere! Real lost
- Just installed Delta 272 Cam
- Racing Seatbelts
- b16a2 on crx... bolt on or have to do lots o mods?
- Ok to run this tire size ?
- quick and easy question re: shift linkage
- bad vibrations
- Keep popping #8 fuse!! Instrument/lisence plate/running light fuse
- Old Drop in Oil Pressure Saga
- Will an OBD0 DA Integra Dizzy work on a B16?
- where have all the 3" exhaust systems gone?
- O2 sensor
- Good deal on a '90 Hatch?
- Sooo I umm...Purchased a new 91 Civic SI today...WOOT.
- Hey
- Built motor question - after cold start quick revs/blue tint exhaust...
- Annoying physical flaw on my CRX
- fryin ecu (yummy)
- Hello everyone
- jimfab x-member crx
- Speedo
- jdm power folding mirrors
- CRX's ... seriously???
- spark prob?
- All of a sudden - code 16
- getting started
- mini-me or zc which is faster???
- is it possible
- Wiring diagram request - Inst lights/tail lights/Lisence plate lights circuit
- b16a Intake manifold and b16a2 Manifold
- best way to run turbo piping in a crx
- disgusting qualitly hood dont do what i did!
- PLEASE.. WHAT SEATS CAN I FIT IN MY CRX?!?!?!
- ***I just spent 200 dollars on these***
- can i use obd0 for a gsr swap
- Anyone know Gregs phone number from GBR tuning?
- HELP! Erratic and sticking idle on ZC
- No Brake Feel At All. Pedal Hits the floor. Whats wrong?
- how long??
- voltage problems
- Seatbelt solution
- POS 91 CRX throws CEL 6 (coolant temp sensor) Wont start now...
- Pin Layout
- b16a turbo crx
- HELP!Mini me problem:timing belt?
- Video of my B16 Turbo / Flip Flop CRX
- crx with 94-95 gsr swap obd1. Parts list? How to?
- Integra shifter work in crx wit hasport B series shift linkage?
- need 88 crx hf info
- anyone make a mount kit for H series in a EF?
- HELP:-( asap!!!!!!!!!!!!
- TwoTone?
- quality lsd
- front bumper conversion
- b16 engine wiring harness woes....
- ITR Rear LCA ?
- 91 CRX NEED HELP ON CHOICE OF TRANNY HELP>!!!
- What rad hose do you guys use for a b16a swap?
- Stock door speaker size
- did some search already question about what manual trans fluid to use..(i use to use gm syncro)
- Quick OBD0 to OBD1 Conversion Question
- SEARCHED: 89-91 Rear LCAs
- Pr4 ls ecu vs. zc ecu
- where to find amber bumper light covers?
- Anybody Looking for Parts CRX EF Parts
- knowing the tranny year
- radiator help
- found an 90-91 ex at the yard what do i need for my conversion?
- CAI coating question.
- idle surge
- Gab shocks on crx
- 1g Crx si / d16a1 question
- After market clutch cable???
- extended downpipe
- Interchangable seats and other parts.
- ....QuesTion.....
- WHat fuel filter goes in a 91 CRX w/b16a??? I thought...
- the never ending taillight drama
- stripping the car
- will it fit
- STD Brake Upgrades
- 88 civic heater core?
- fixing leak tips please
- need a quick answer
- installing an S2000 gauge cluster????
- crx body kit
- LS Turbo Build PLEASE HELP!
- 89 crx door panels NEED TO KNOW ASAP
- EF8 tach inaccurate
- motor swap
- clutch question....please help
- Will 91 Si DRIVESHAFTS fit on a 89 Civic DX manual
- what the hell is a turbonator
- CRX - Civic compatability? URGENT!!!
- ITR calipers on CRX?
- How to ship a SIR front end?
- CTR FINAL DRIVE>>
- My Hatch
- Bad thermostat? I've got a big problem, urgent help needed.
