View Full Version : Honda CRX / EF Civic (1988 - 1991)
- gsr cluster qucick ??
- hey LSvtechatch97!!
- converting ecu at to mt
- pulse in brake pedal, escpecially on highway - anyt thoughts?
- Suspension/brake info
- does hond ahave a center cap for a 56.10mm bore?
- I think my car is cursed!!!!!!!!!!!!!!!
- Cam Or Head ?
- damn now it runs funny
- ...no tech. just videos. why track days > drag racing
- Need opinions on a trade
- The springs in my clutch are loose - is this ok to use?
- will ac stuff for a 92-95 civic work on a ef?
- questions about trim
- B16 Swap Front Motor Mount Problem
- Best sounding Exhaust setup on a 1991 Civic...
- wingless hatch?
- turbo or supercharger?
- red recaro itr seats in crx
- Hooking up FJO wideband. Says to tie into ecu power supply. Which wire is it?
- upgrading an si
- convertion to (mpfi)
- about to buy 91 si yes or no? suggestions plz
- Project 88 build up.
- using obd1 throttle body
- RTA bushings need advice (searched)
- vtec oil/ sileniod
- permanent rear windows in ef hatch... SEARCHED
- B16A problem idle
- theorys on which intake (not asking what to buy)
- New/confirmed OptionJDM.com front lip info.
- parts for sale
- Rebuilt Motor!!
- Bent front crossmember. how?
- Its a sad day when a CRX owner is seeking oil changing advice
- jdm crx
- Need a good camber kit.
- EF8 import in Europe
- making your gauges red including your clock
- Did I damage my valves?
- CRX-keep d16a or swap?
- Help with Race CRX
- throttle pulsing
- Turbo tuning.
- hey guys, i was just wondering how much it would cost to install some new pistons becuase mine are s
- rust on tranny. safe to put on?
- ZC exhaust manifold
- question about omnipowers, or any coilovers
- B18C1 swap trouble
- Integra GSR Hub vs. CRX Si Hub, revisited.
- 85-87 dual proportion valve
- swap
- oxygen sensor
- ZC intake manifold
- Need help with picking the right highflow cat (EF gsr)
- gsr ecu
- 4 x 100 Wheels, Options?
- need diagram for the dizzy for the two white wires
- Project Log of 90 CRX HF with a JDM h22a swap!!! 10 lbs of shit into a 5 lb bag!!!
- 1991 crx supercharged iddle control problem
- zc into crx
- Header Wrap
- Poor CRX
- What is the cheapest way to build a fast rex?
- help??? on HT
- Need to swap out pedals, what brand names are good?
- anyone see the "carbing"/pass.JDM 3pt front strut bar???
- Help question with b16a swap in civic
- Jackson racing charger install on B16 CRX
- Transmission Fluid Question
- quick newbie question.....
- BIG BOY SPRAY
- finnaly got a b-series
- jdm 94-up integra cluster in 89 civic
- D15B7 block with a Z6 Head + Turbo = good idea?
- my cooling fan not coming on ? already check fuse !?
- I have a question for anyone how has hid there wiring under the hood.
- who makes d16 dual valve springs>???
- why
- Getting started ... what do I have here?
- So since 2 days ago my car started to acting up on me....so my question is ....
- d15b, what aftermarket rods?
- Any thoughts on KYB AGX shocks??
- Car info needed...
- D15 or D15!?!
- can someone tell me how to change the windshield wiper motor
- tire recommendations
- replacing brake line
- Acura and Honda Engine List
- Question about CRX Speakers?
- lsd?
- car troubles, was fast-slows down- dont run at all
- Exhaust advice.
- Jdm glass roof
- something wrong with my rex?
- won't start!!!
- stopper for sunroof
- Why do I need to Honda thermostat?
- car running rich will safc solve this?
- wtf is with these wires....
- My first ED8, comments welcomed
- b16 $$ ?
- ls crx quarter mile times
- civic ef blue
- exhaust under rear suspension
- h22
- yes yes...another crappy idle problem
- What does this part do?
- 90 crx sunroof
- what to do with 84 CRX 1.3
- ZC Starter? What ones will fit? & VSS Test and Removal?
- Intake question.........
- Alternator for a JDM 88 CRX si glasstop?
- CEL's, white smoke, etc... HELP ME! (long-story)
- CRX injectors
- We got the motor in!
- dohc zc into 90' civic dx
- help..
- parts for dohc zc
- what ecu for a dohc zc
- d16a6 swap on a DX ??sluggish! using b16 injectors ok ?too rich??bogging?
- dpfi to mpfi
- Right hand side exhaust for crx
- dpfi to mpfi problem please help
- destroke crank for d16
- RHD parts
- B18 - What's the difference?
- HELP!!!! No power to radio and clock!
- Anybody try a seat pan sawp with a CRV seat?
- EF9/hatchback rear speaker pods
- D16y7 swap and Problems running... No Fuel, No Spark
- first time at track ls
- itr cams/b16 cams
- after market lca's?
- Password JDM 3 point strut tower bar to be release next week
- NEW crx need wiring help
- black strip of metal above rear window on crx...
- Lower Ball Joint
- wtb crx jdm fenders
- where and how much to rewire my whole car
- At What Speed Do you Shift at?
- Largest muffler fit in stock location
- sooo heres a noob question...
- 1989 EF Honda Civic
- I WANNA LEARN
- white rims on a white EF?
- crx and Ef exhaust?
- will DA callipers bolt up to ED spindles? searched
- will safc make my car run better since its running really rich
- no check engine and no vtec plz help!!
- AH!!! got an 88 ZC tranny with a 89-91 clutch an flywheel assembly!! what do i do???
- B16 Trouble
- Crx Front Brakes.
- Brand new swap....Having problems.
- b16 ef hatch...please help!
- Interchangability, 884dr, 88CRX, and 89 Integra
- CAI in EF
- looking for more power sohc Zc isnt cutting it
- question for those who have done obd0-1
- removing stock steering wheel.
- wiring of distro to ecu
- searched my heart out, any help please!
- Dohc zc code 8 TDC
- parts parts
- How much can u fit?
- what stock honda wheels fit the EF
- I I have a chipped ecu and remove the chip.....
- Honda 91 Crx engine knocking!!!!
- wings west body kit 91 crx
- which intake manifold are the same with the d16a6 ?
- CRX Tachometer Help
- my shifter dropped. argh
- Help me Find A Color for my CRX
- 92-95
- brake problem- need some help-
- Evap Canister Q and A
- i need help dam check engine light on
- TEIN BASIC vs. Omnipower... experiences only!!
- ANY REX'S FOR SALE?
- fully built b16 vs. k20a2
- brand new parts for sale!!!!!!!!!!!!!!
- Newb question about o2 sensors
- motor ?
- OBD2 B18C(R) EF RUNNING CAN IT RUN OBD1
- First gen CRX question, need advise!
- help me: cel 22
- d2 coilovers (I searched)
- What civic models came with PS, PW, PL, AC, PM
- Who has done a B18C1 swap into a EF?
- Wire Tucking Concerns
- b16a jdm exhaust system
- New motor
- Need B16. Portland Oregon Area.
- Need help fixing idle problem on DPFI CRX
- Sohc ZC tranny
- 91 civic Tach Signal Wire
- 92 civic h23 axles?
- swap
- >>>mini me? head bolts
- Exhaust Header with 2 O2 bungs???
- will new tailight gaskets actually stop my car from leaking?
- sohc question
- dpfi to mpfi searched and couldnt find!
- Streetable aftermarket big brake reccomendations??
- Which quaife is better? 40mm or 35mm bearings?
- Getting a CRX next weekend.
- b18 swap into 86 crx si?
- alarm question
- Swap Time
- so, can rear 90 wagon struts fit 90 crx for a better ride?
- b18a1 or b20
- ZC Tranny Swap
- How much does the Rear Hatch Cover Go for?
- Debating on what motor i should put in.....
- Do all D series flyswheels and starters work together
- need some advise
- Smashed my CRX!!!
- Holy crap I love red necks!
- CRX 1/4 mile time just in
- 5lug conversion issues
- Electrical Power Loss
- My plans for my EF (Read and post your Comments/Views)
- sohc zc in my hf. should i settle for a pm6 ecu??
- Battery Light "surging idle" and Main relay...
- CRX MESS...STATE REF needs to be impressed
- Intake question
- How do I know if my radiator fan is working?
- which suspension for dd/autoX H&R, Progress or Ground control (did my homework)
- trouble with my b16a
- weird exhaust sound at idle...
- DPFI engine harness diffeences?
- sohc ZC motor running really rich
- trouble starting in the morning
- B16 Knock sensor
- whats the best oil to you
- B18a1 onto a 88 CRX HF questions
- first engine wash, got a question
- Suspension set up??
- VSS cost?
- quick question on offset?
- injen parts good for honda's ???
- p28 ecu on b16...what engine harness?
- d15b or d16y8
- Swap finished
- flywheel
- cv joint aaaargggggh
- TPS SENSOR PROBLEMS
- ENGINE SWAP HELP ASAP B18 OR H22A
- burning oil but where?
