View Full Version : Honda CRX / EF Civic (1988 - 1991)
- About to buy 88 HF CRX
- I need a coilovers company to make me springs with custom rates.
- b18a w/ YS1 cable tranny into 91 EF chassis, which clutch cable?
- Whats my car worth
- My CRX Build
- Please help engine swap time!!
- Engine Resore for my compression
- somebody hurt my baby
- steel braided lines and bremos?
- weird belt noise
- Testing the waters for a product
- SOHC & DOHC ZC trannies? Any differences?
- b16a or b18a which is cheaper??
- 4g63T in a crx?
- 11"-what brake lines?
- New to cable...dont really know how it works.
- allignment
- GOLDEN EAGLE FUEL RAIL BECOMES LOOSE
- Heater...and a kinda off idle
- Low RPM studder when warm - after mini-me
- mpfi swap crank angle sensor and iacv
- Help with taillights
- anyone using the noligy silverstone sparkplugs
- HELP ON SWAP!
- Last Resort ?
- newbie needs help on b18 swap
- 90 DX Hatch WON'T start ???
- how do you remove retaining nut from steering wheel?
- removing paint from polyurethane bumper
- PM6 help
- 90" civic hatch si
- ecu help
- Will an 88-89 interior fan fit a 90-91?
- auto D15B vtec won't start.
- WTB: CRX black interior & CRX SI throttle body...
- clutch replacement
- Doors not lining up?
- 83 civic hatchback 1500cc
- Need to identify this ECU
- ANYONE HERE HAVE 91 4DOOR WITH A SWAP "POST PICS"
- help with brakes.
- Is my ignition screwed? Need help - driving a Buick now!!
- Eg and EF part compatability
- need help with mpfi swap
- http://www.turbodrift.com
- Any H22 swaps?
- Where to find VIsion amber corners for 90-91 Civic?
- Pop Pop!
- Was looking on Ebay, WTF is this???
- Anyone have any experience with this place?
- Civic SI-R B16A 88-91 Swap?
- New CRX?
- Just out of a curiousity?
- SI tranny on a DX engine?
- quick question
- worlds most expensive CRX
- easyest swap no b
- b18c5 in a 91 civic hb??? anyone have pics????
- ~~ 89 CRX... daily driver... beater... planning for future suspension. coilover setup
- What Axles are best to use for B16a Swap
- Video of my 88Si @ 1/8 Mile Strip.. Quesion-
- b16 into an ef
- Anyone know how much the Skunk2 Full coilovers cost?
- What type of head would be best on a dx bottom block?
- crx header clearence
- tunning question
- CRX and EFs are old. What do you think about these smog "assistant" products?
- mini-me
- pics of my car
- Possibly parting out a 91 ex sedan.
- WTB: B16 swapped CRX or CIVIC hatch
- PM7 Ecu....Need more help..
- What kind seats can be put into 85 crx
- overheating, clicking noise, wont start
- were to buy tranny rebuild kits?
- Mileage for swap engine?
- brakes on 90" civic hatch
- greddy type s bov
- Lights! Lights! Where do you buy bumper lens? corners? non clear euro ones? CRX
- need help with installing valvesprings!
- Transmission/mosty shifter problems
- EL Vap133
- Did 2nd generation CRX's come with the louvers/blinds or were they only for 1st gen
- Falken 205/50/15 with 15x6.5 +45 offset good to go on a CRX?
- help me pick out a header (searched)
- In need of a D16A6 block!!!!
- where does everyoe buy there parts from???
- ANY ONE GOT A 90 HF CRX PEDAL ASSEMBLY IN GOOD CONDITON FORSALE I NEED IT!!!!!!!!
- Ingalls front camber kit install.
- vtec oil pressure wiring?
- Bulletproofing Engines/ B18B or B16A?
- !!!!!!!!!!!!!!!! condensor fan !!!!!!!!!!!!!!!!!!!! ???????????????????????????????
- wtf is a b15?
- 4dr Power window tracks in EF
- zc swaps good or no
- Where can I find adjustable radius rods?
- How Reliable is LS/Vtec???
- '94-'01 Teg axles???
- ZC distributer wiring PLEASE HELP!!
- Has anybody tried dynamat on their cars?
- dohc zc code 9
- code cps on b16 where is the cps i searched..
- My motor woes... need to pick your brains!
- Another fucking thieve story
- NEED A 89 EF civic front bumper right headlight, and fender (socal)
- Whats on your "to-do" or "to-buy" list for summer
- *searched* right springs/spring rates for a bseries swapped crx (b20), which brand?
- HF motor Question
- any turbo 91 hatch's
- 91 civic starting
- i need a harness
- help on tranny problem
- Front wheels locked after b16 swap HELP PLEASE!!!!
- CRX/EF Bumpers, hoods, fender question
- Please help me troubleshoot this puppy.
- si cam in dx?
- lookin for mini me swap parts
- Hi, new around here and had some questions.
- Does this look like a bad oil pump?
- ExcessiveCRX's Project Log
- d15b question
- sticker removal
- Fuel Filter
- my second honda, my first hatch, my first attempt for a swap
- Need pics for clutch install!
- High Pressure fuel line busted!!!! your feedback on this pleazzz
- brand new clutch cable
- What ECU is in my car?
- Troubleshooting help needed
- Interior Color
- mpfi swap question.
- anyone with a dc catback?
- this is gonna sound stupid
- GSR into 88-91 civic 3door help
- Looking for the JDM crx conversion please help me out??
- need ys1 cable tranny
- You might be an ef'r .......
- a CRX for me..FINALLY!!!
- B16A2 turbo questions
- Add another stolen crx to the list
- Spline count on zc tranny
- After Motor Swap.
- chianti red
- put in tech but no answer (did a search)
- gsr intake help
- Wiring Vtec on ECU??????
- Someone Please Post a Video of an H22 CRX.
- how to get the shift nob off
- anyone know where i can get itr engine swap???
- new exhaust
- Ls-Vtec
- 1987 Si ?
- HELP ME!!!!!!!!!!!!!!!!!!!!!!
- 91 crx ZC Dual point to multipoint injection
- ACT clutches streetable?
- Changing clutch disc..
- What do you guys think of tint on a red hatch?
- Need help with idle
- Rear disc conversion on a 88-91
- What ECU will be better on a Zc?
- is it possible to put a v-tec head on a zc block??
- Dizzy qustion
- 88 DX tranny HELP!
- need help with resistor box!
- 1.3 ZC swap
- JDM vs. WW vs. USDM
- Who is running a spare tire in there DD?
- What is causing this?
- My A6 NA Project (HMT Style) 56pics
- Whats the difference on a PM6-A09 and a PM6-L09?
- i forget what mounts you need!!
- help me!!!
- 88DXCRX...Need more ECU help.. Or anyone else..
- got some ?s on z6 head and tb
- YS1 tranny question
- Help with LS fuel rail on AEBS manifold.
- ZC or d16 vtec in a 91 civic dx
- HF manifold?
- what trannys are these?
- Pics of my 1st EF
- CALLING ALL IN SOUTHWESTERN ONTARIO
- How to do vac lines???
- ITR calipers and Prelude rotors?
- car wont start
- Is the dohc zc crank pulley the same as the hf one
- will 90-91 CRX si rims clear EX 10.2" brakes?
- hey everyone
- Need a lil' help here!!
- built, but troubled d16 engine issues
- Left axle Problem!!!!
- lights on the dash
- ALL MOTOR B16 REBUILD
- O where O where does this wire go...
- New project i'm a newb, need help
- crx exhaust on a civic??
- HELP, key wont turn in ignition!
- Interior Fan Not Blowing....and I live in Canada
- just got a 90 hatch, want a cheap easy swap, maybe a6, or ls is even better
- No spark - help please!
- b16a2 turboed vs b18c5 na
- how hard is it to do a minie-me
- rear control arms?
- So you bought a EDM PM7 ecu...
- OEM upgrades?
- ZC tranny onto d16a6, any problems?
- Where can i get thin side moldings for a ef hatchback
- wheels
- B16 Swap Problems.... Someone help me
- d15b2 plug help
- What should I buy for the Spring 05 return of my SI?
- test waters.....Civic 91 Si for sale!!!
- 1.5L civic help!
- Top Knotch Cams for ZC DOHC?
- edelbrock performance x manifold
- leaky hatch
- l/s intake manifold clearance?
- RWD CRX!!!!
- fibreglass door skin?
- CRX B16 WONT RUN
- code 41 resistor
- EG exhaust on 85 CRX?? Any ideas?
- Car choking/dying under half a tank of gas...fuel pump?
- fuel pressure??
- 1st gen swaps vs. stock motor work
- CLUTCH GRABBING POINT IN EFs
- dashpot on the throttle body?
- what happened to the crx resource?
- B16 speedometer question
- 91 teg ecu swap
- 99-00 si cluster in rex
- hatch release/ fuel door release levers
- windshield swap
- Need Ecu help..Just to find out what it is.
- Fast help...(std) w/crx SI steering wheel
- D15Bvtec fuel problem? Or timing?
- crx seat aftermarket seat brackets
- SOHC DOHC
- car wont go ?! help !
- Mini-Me Gone Wrong. (Already Searched)
- What year doors are interchangeable?
- Charcol canister/
- my intercooler piping custom made by me
- smog test numbers off the scale...........HELP!!!!!!!!!!!!!!
- blown head gasket... how much to fix??? and turbo seals gone?
- just got my z6 head
- Clutch Price?
- oil pressure gauge
- replacing quarter panels
- SOHC ZC = d16a6 smog wise ????
- Question about my car????
