- where to get hcp mounts?
- modifying y8 distributor for mini me
- fs: 90 si hatch
- WW kit
- Brake ?
- $300cdn for d16z6
- ZC Timing belt tensioner ??
- ek sunroof motor in a ef
- do i need a better ecu?
- Real coil-over systems
- crxsi d16a6 0 miles f/s
- What tranny is this? PLEASE HELP ASAP
- how do you wire the jdm headlights on?
- Any1 got a pic of a CRX w/ AV3's?
- turbo
- gsr susp
- how to identify if your b16a1 came from automatic car?
- Will a 88 model teg d16 fit into an 89 honda crx?
- ls vtec + nos
- Will 93' prelude rims fit on my 91 crxsi
- Tranny SWAP PLZ HELP!!!!
- Patch Panels for rear quarters on an HF??? Anyone??
- Koni or Tokico
- Going turbo SOHC VTEC in my HF I think...
- b16a1 (jdm) --- Is the OEM injectors saturated or Pintle??? Using the PR3 Ecu
- Motegi MR5's
- Question inside!
- CRK BRAKES
- 1990 CRX Wheel Offset for 15" wheels
- Almost done!
- HELP ME PICK A MOTOR
- Need pics of sensors....
- exhaust and bars FS
- Passanger door lock is buggered...
- HASport mounts?
- What can I use off this?
- Ride like a lexus
- 90 crx starting problems
- ZC timing ?
- Help with a '91 Civic DX Hatch
- Anybody heard of this nitrous kit?
- need info on 4G Civic Si header/intake upgrade compatability with stock ECU
- So Cal EF Meet 2-3-01
- gauges in dash of civic
- My crx, before and after.
- 90 Si HATCH FOR SALE
- WOT: My new Project
- Race cam & Head Forsale
- high CR
- modify an automatic to a 5 speed on a 88 crx
- aftermarket crx cam?
- trouble with ecu
- CRX w/B18B motor having problems...
- pasadena meet confirmation
- anyone have a dohc zc valve cover for sale?
- Question: Can CRX Exhaust fit on 88-91 Civic Hatchbacks?
- What brand for FPR?
- Bronze lenso slicks, link to pics work finally.
- apex n1 exhaust
- 88 suspention
- Physical diffs between 88-91 and 92-95 SOHC header
- ZC info links list
- Attention all rexers
- Blown valve cover gasket! WTF?? Why did it happen?
- crane cam question for d16a6...
- Guys with SOHC VTEC in an EF
- What do you think ???
- some of you were wrong on a clutch question...
- center console
- rear bumper
- Code 22
- buy a piece
- CRX Exhaust
- it is possible
- anyone want some CRX headlamps?
- gauge clusters
- hydralic tranny install???
- Question about headlights?(please help)
- Hep! post pics of your H22 swap in a 4 gen civic/crx
- Mini-Me on a 1.5 JDM Twin Carb.
- head swap
- wheres the ecu on an 88 civic hatch?
- 4th gen civic hatch dx indiglos
- info honda
- DOHC ZC with NOS? how long do you predict it will last?
- Sohc vtec-1.5
- minime guys.. or anyone for that matter..
- how expensive is re synchro of a trans
- hesitation
- ecu?
- b16 swap into civic std.
- Is This Normal for a sohc 1.5L?
- can i use a OBD1 OR OBD11 ECU ON B16A1?
- in the shop
- honda bulid up help
- zc?
- what brakes???
- LSD on a crx?
- Del Sol
- Does anyone know where I can find the fend that covers the front corner light on a crx
- New looow price 91 civic hatch
- n20 on mini me
- How long do all you plan to?
- Which tranny?
- Got bronze lenso drag rims. Need advice, slicks 20 or 22 inche for all motor
- SOHC ZC Engine specs?
- changin the key switch in a first gen rex
- Gas milage?
- Mista Bone and other D series boys
- Fawwwwwwwk Me! o2 help needed again!
- Got my first spot of rust :(
- 91 civic VT-i (B16A1)
- Rear windshield fluid not working!!!
- 88 silver crx si for sale
- WTB ASAP: 89 CRX SI engine harness
- VTEC solenoid questions
- the begining and the end..of what could have been...
- removing front bumper reinforcement for weight reduction in 91 hatch
- Trouble with LS
- FS: 4th gen "Civic" decals
- rough start on my d16a6...
- b16 installation instructions?
- What's up with this.
- 89 CRX Si starting problems
- Help me diagnose.... '91 EF Si
- ecu??????????????
- zc hp and cam gears
- Radiator?
- How do you read the code on 89 hf?
- honda termanology? usdm, jdm etc.
- Who has the cheapest price on b!6's
- How much my crx worth ( i'll sell it soon)
- 91 civic hatch
- vtec solinod gasket?
- B16 + jdm 4-1
- OMG WHAT A DIFFERENCE!!
- prelude injectors
- ZC / Si Tranny Help
- how to install rear lower tie bar
- Qs on 3rd gen civic wagon
- WTB: motor mount kit for bserie
- tranny what's the code for 92-95 cable
- b20 to replace the b16 base
- Installed Short Shifter and Bushings
- Fastbrakes 10" 4 piston kit product update
- b16a in 91 civic overheats only in traffic???????
- 90 Civic LX-Need help-no start
- Free Head Light Buzzer
- Has anyone ever put an H22/H23 into an 88-91 Civic/CRX?
- old school teg ecu for automatic MPFI swap
- b18c1 in crx need help plzz
- Why are so many people doing 92 DX MPFI swap in their CRX DX?
- gsr shifter
- Flywheel
- to all d15b owners, what is your whp and torque?
- Cut bumpstops or no?
- DSM Fuel Injectors
- B16a sizes??
- rods
- Fastbrakes track tested...
- Has anyone ever put a 2nd gen B16a into a 2nd gen. CRX?
- suspension question
- Air/Fuel Gauge Question "4th gen related"
- Versus motorsports
- crx hybrids
- need tranny!!!!!!
- si harness
- CRX ?
- auto to manual swap
- turbo on d15
- Weight Problem
- INFO please!!!
- HELP! Front end conversion for my EF
- How do I get the sunroof rails off?
- 88teg distributor on a zc
- wiring harnes 90dx ----90si or si wiring
- Weird noise when I start the car...
- Differences between 88si and ZC tranny?
- ZC cam shaft
- B18A into 88 CRX HF
- Swaybar question...
- trouble codes with vafc
- Si sun roof in a dx?
- 90-93 Integra GS Cams and Gears
- Black stuff in my hatch
- CRX SiR B16 Transmission Question - Shift Rod/Selector Rod Oil Seal
- OBd0-to-OBD1 conversion harness groupbuy......
- People suggest an LS integra swap
- will teg tranny fit?
- New on the board
- anyone have a 91 si front lip for sale?
- H4 bulbs, aka Si-R front end
- accord wheels 4x100?
- 20 or 21 Input Splines for civic 90
- i need HELP...........
- WTB: ENTIRE 88-91 Si (crx or hatch) powertrain
- Is 90-93 'teg LS engine a ZC or B18? Does D16Z6 drop right into 90 CRX Si?
- 6th gen radiator swap --> CRX SiR
- piston
- WTB: B-series swap parts for EF
- integra problem, can civic ppl help out alittle too.. since teg are similar to civics
- tranny for ls/vtec
- How do u fix ur hood release???
- It finally came back!!!
- ZC TRANNY
- cheap
- 'Teg ECU w/ New Cam?
- b16a second gen with first gen tranny
- ALL MEMBERS READ!
- stock Si fuel system
- pics of d16a6
- any one know how to put hydro tranny on a cable need to know the how too!!
- 2 CRX's f/s:
- which cam with my setup???
- Sunroof Options?
- d16z6/d16y8 block w/ d16a6 head
- 10.3 inch front brake swap...
- Wich rod bolts?
- engine build-up q's
- Sohc tranny users..New F/D info
- CRX glass top question..
- My New HF
- Any CRX Si's for sale in CA?
- life of a tokico shock?
- what are the symptons of a car with these troubles
- 4th gen sedan with Neo combat front bumper
- setup
- Help: Intake question for my b16 ef8.
- SCrews theives and there momma's too!!!
- DPFI to MPFI
- Mid to South Georgia residents look here (N.Florida too)
- Ecu chipping...
- Question- What years Integra seats Front AND back fit the 4G Civic HB
- Why was my post erased, I ask about a GSR bar fitting a 91 Si?
- Will 90-93 integ Lower tie bar fit on an ef civic hatch with 90-93 LCA?
- Crank pully removal
- distributor interchangeabilities
- witch b 20 should i get
- B16A
- Tranny problems
- Car for sale
- wat does i mean when the battery light turns on?
- the shop finally..
- ls motor for crx
- Which brakes to use
- Any knowledge of suspension upgrades for 86si
- which is a better intake manifold ?
- Stock Si seats - Weight?
- anybody got a built d15b7? (93 dx) turbo? nos? 1/4?
