View Full Version : Honda CRX / EF Civic (1988 - 1991)
- FRONT LCA WHAT CAR DOES IT BELONG TO?
- D16Z6 Fitment in Honda Civic Shuttle ('91)
- Brakes = FUBAR
- built b16 turbo overheating
- valve seals?
- 91 Civic Lx ICU help - wipers and blinkers don't work
- To restore the crx or not to restore
- Ohisofly's 91 Crx turbo ls build thread
- 90 civic timing belt issue?
- Wheel Fitment/Advice Please
- s80 tranny in crx?
- ef sedan with d16 swap automatic tranny
- picked up a 90 Civic DX with Vtec swap with rev limit issues?
- d16z6 swap into ef
- 91 CRX ground up purpose buid
- Basic 1988 ef hatch d15b1 b16a swap need some advice,
- Header/test pipe to catback combo help
- What iacv can you use for a d15b2 dpfi
- 12.1v idle, too low voltage!
- '91 Crx swap?
- ef civic clutch not disengaging
- How do you load/torque after replacing all suspension/balljoint
- 87 crx hard start
- 1990 civic retrofit ac question
- 91 auto dx question
- Help With Possible Bad Ground? 91 CRX SI
- 91 crx b16a 1gen no spark
- crx fender skirts
- Bad Gas Mileage. Searched. Still need help.
- Civic 91 high rpm after engine starts
- 90 Civic SI/DOHC ZC OBD0 - Can I use a stock SI trans from this year?
- 1990 DX cluster lighting issue....
- 8 Valve Timing Spec? 12 or 18
- Black Widow kit
- driver side halfshaft wont go into diff
- 91 civic ex/d16a6 - need help with D16A8 swap
- Chassis Stiffening
- correct radiator hoses
- My 1990 Civic DX Finally Passed Smog!
- Throttle body for Mini-Me AUTOMATIC!
- 91 CRX Si getting 98 DC4 upgrade?
- most cost effective build for 150-180whp?
- '91 Honda Civic HB sunroof parts
- thieves jacked my ride...
- 88 CRX Si driver axle pinches back of hub, help!
- 91 civic dx h22 swapped wheel hop issue
- Axle seal keeps leaking
- Seatbelt Arm
- Manual d15b2 vs Automatic d15b2
- jdm d15b re ringing question.
- JDM 14x8 rims. tire size help?
- Easiest & cheapest swap ? D15 to d16 help pleade
- Pgm fi to mpfi on d15b2
- 1990 Civic Wagon Timing Issue
- MIL blinking continuously. Can't diagnose any code!! HELP
- CRX caster issue? radius rod?
- eg suspension on ef
- Honda Access rear armrest ?
- idle problems PLEASE HELP!
- Civic Rear Rebar on Crx, does it fit?
- Spoon Brakes Setup
- Brand new in box Civic hatchbach 90-91 rear garnish lens
- Problems w/Accelerating Uphill
- ef ac questions
- hybrid suspension? dc into ef?
- So I just bought this used 89 Civic HB....
- 2nd gen CR-X rubber door trim?
- Won't pass smog
- '91 EF - pulley coming off the crank
- Exhaust piece?
- 1990 Honda Civic Ex
- 91 Civic Heater blower motor problems
- EF won't crank
- CEL Problems!! Can someone help!!
- CRX Hf D15b7
- After market rev limiter onto B16A1 OBD0?
- Frustrated Civic lost compression after sitting
- Hasport Vs Innovative
- D15B2 motor with v tec head swao help
- Bushings
- dropped a washer in lower timing belt cover on Dohc ZC, not sure where it went?
- whats safe to use to clean oil off timing belt?
- [HELP] D16A9 Rocker arm
- ef hatch w/ b16a swap won't start PLEASE HELP
- 90 hatchback std ls-v build
- 86 si Need help keeping it running
- 88 crx si radio wiring
- black grease on fire wall
- 1990 Honda Civic Si "Taillights Problem"
- Crx Project (Im 13)
- 91 civic egr problem
- car will not crank over
- 89 HB b series shift linkage removal
- faulty or wrong fuel pump
- 1990 Crx si motor swap to 89 DX motor
- Crx si underdash harness help
- 1990 Civic STD Problems
- Parking lamps In-Op.
- EF auto trans rpm at 70mph
- Help with COILOVERS!!!!!
- yes or no
- gauge cluster doesnt light up
- Motor mount bolts?!
- 90 Honda Civic LX blown head gasket and want to change to 92-95 d15 Need help on swap
- frequent ignition coil failure
- F20B in 91 Si. custom axles ? help, lost
- Skunk2 Ultra street intake in a ef
- 91 si stock cel resets itself please help
- Oil leak in spark chamber
- 88 hatch sometimes runs on 3 cylinders
- 90 crx si no spark HELP!!
- did one of these spin a bearing
- Some thing's wrong here, traction bar install?!?!
- Power folding mirror problem
- I Need Help with my 87 crx build
- Wagon bumper on hatch
- ISSUES! mechanic installed si trans in my wagon
- PLEASE HELP!!! Stock 91 civic si
- Early 88 crx si clutch spring Q
- JDM power windows with universal switches and relay?
- CRX noob, CV boot, broken tachometer
- gauge cluster problem help!!!
- honda ef wont crank
- Distributor Bolt issue help!!
- what are all the things that the oil pressure sensor do?
- Starter issues Please help.
- will a 91 sedan glovebox fit a 88 hatch?
- hackjob underdash wiring help please
- Power steering fluid leaking out after starting car at -34C
- 81 CRX - Would like opinions and a little info on Engine/Tranny Swap
- 91 civic issues
- 88 ef hatch shake high gear low rpm
- half radiatior
- Ef hatch idles but doesn't drive
- 88 SI body parts search
- walbro fuelpump/fuel tank gasket
- How to clean coolant overflow container?
- cluster electrical issue
- crx front coil springs oem
- 88 91 crx hf d15b6 motors
- new to the game looking at a car
- Steering rack problems/brake vibrations
- Will this work? Rear disc set up from a 94 Integra
- Type R swap question
- my car after paint job ef civic
- Recommended oil filter does not fit.
- I can use some help
- **HELP** 1990 Honda Ef Hatch motor issues
- is yonaka a good buy for my ef hatch?
- 91 crx driver side lock wont work
- d15b2 trans
- 91 civic wont start randomly, wont turn over d15 motor
- Help Please!!!
- B18 Tranny Went Out, Good Source For One?
- CIVIC 1987 starting problem
- so confused, (obd2 ef conversion)
- f2b vs k20a
- 1989 Honda CRX Brochure
- Need help with my swap.....
- 91 CRX Build
- Tach Problem?
- 2.5 donut flange advice needed
- Where to buy J's Racing/CS Replica front Lip for 90 CRX?
- D15Z1 ebay pistons
- 91 hatch build!
- Question on corner light bulb
- EF Civic Cracking/Creeking sound when accelerating from a stop.
- cabin obd0& beam engine obd1
- ZC means 1.6L D series
- 89 civic restoration and build. saving a classic
- front turn signals dont work rear do???
- ef b16a smog california
- Instal Help
- I am looking to swap to a vtec?
- CRX shell again
- Differences between PW0-000 and PW0-X00
- I need Honda civic CVT tCM 28100-PEJ-013 Pinouts
- 90 civic hatchback wont start when really cold out!!!
- Bouncy idle on start up ( only if I press the gas )
- Spindles Help
- EF AWD
- mpfi Si stuff question
- compatibility question
- crx hood release cable
- While this motor is torn down, what other maint. would you recommend>
- can I swap blocks?
- confirm yes or no lsd
- Launching my EF
- I cant Believe I Did this...
- IAT Valve!? Mini-Me swap question?
- Need help on wheel sizes and offsets.
- 88 si z6 injectors wont pulse
- Seats that fit a 90 hatch without modifying them
- D16 for 88 crx hf
- Civic Wont start, D16Z5 swap
- Best struts to go low with?
- Fun in the snow
- Front window regulator - same for hatch and sedan?
- running resistor box with high impedance injectors
- alignment guy bs-ing me?
- 91 Civic hatchback blower issue?
- D15 head build help
- EF Civic Hatch - Trasmission will not shift
- saturated rc550s help pleaseeee
- Skunk2 Coilovers
- CRX @ b18c4?
- PLEASE HELP! 91 Civic Si Door Checker Repair ................................ Picture
- Need help with 91 Civic
- California smog check fail- guy didn't understand how I got these results.
- 90 si with b20 vtec.. failed emissions test
- Power Steering Delete
- CRX Aphalt Oval Track Car
- Low gas mileage code 8 and 9
- My Wagons New Tuck Harness
- 88 CRX BUILD
- 1991 CRX Si K20a-R Swapped
- rear eg si effect sedan rear seats
- Please help! car jerks and rpms spike! what's going on
- Buying a Wagon
- O-Rings for PGM-FI fuel injectors
- multi-function control unit rebuild?
- Dual Center Exhaust?
- Looking to go K on my sedan
- 93 Integra GSR DB2 (Front rear) Cross member on EF ???
- crx suspension forks
- Resurrection of CR-X
- D15B2 12mm and 14mm Crank Pulley Bolt
- trans rebuild kit?
- 91 Honda Civic SE Service Manual
- Inner Tie Rod. Moog or Beck/Arnley
- EK square fogs on 89 EF
- D15b7 throttle body
- whinding sound
- Can't find a replacement CRX rear bumper cover
- Multiple issues? Cold heater & no cooling fan
- Help! CEL and sputtering
- D15B vtec OBD1 vs OBD2 engines swap over help please & thank you
- track rod snapped
- bad gas millage and loss of power on hills!Catalytic?
- Buying used rims...
- how does the rear fender edge trim attach ?
- 1990 SI Fuel Pump Install
- '90 CRX DX (ED835) converted D15B P08 (help)
- d16y8 swap question, 89 EF
- Civic Distributor from RockAuto.com
- Got my first Honda
- non-stop Axle problems!
- 90 lude seats in 90 sedan
- different tire size
- crx help
