View Full Version : Honda CRX / EF Civic (1988 - 1991)
- is ls vtec good for daily driver?
- Advantages of Carbon Fiber hood?
- Which wires to switch?
- lower ball joint replacement techniques
- mods: where did the classifieds section go????
- Where to buy piston rings for the d16a6?
- Timing?
- Do I need to get new valve springs to run Civic Type R cams?
- 4G4Dr Suspension Swaps?
- Steering wheels turn, but wheels won't?
- what's the most to pay for a crx rear brake conversion ?
- Honda civic VT problems (B16A)
- Will the drag turbo kit fit w/ the stock radiator?
- b18 swap question!! brackets!
- VTEC ACTIVATION PROBLEM
- Not tech related, but thought everyone could get a laugh
- CRX Wiring Question (not swap related)
- will 00' Integra Type-R suspension fit my 91 EF?
- which fuse resets the ECU?
- 23 knock sensor
- b16a coolant lines that run thru TB and intake mani
- obd0 pr3 b16 erratic idle.
- Civic EX/Si CAI
- which clutch fits S1 cable?
- will a front bumper of a 90 fit a '89?
- car sits higher on one side!
- Anyone used Turbo Edit or Ostrich on their obd-0?
- Code 17, weird one
- Fuel Pump replacement in an 89 CRX Si
- Tap-its?
- can you put a k20 in a crx?
- Coming back to the dark side!
- somone sell me ther crx in the tristate area
- DOHC ZC headbolt torque?
- 2 CRX Questions from a new CRX owner
- starter question.
- Having a serious issue with my car, please help!
- rear brake parts inquiry crx
- Running wires in engine bay a few questions about harness
- what color would you paint it?
- VTEC PROBLEMS
- DOHC Zc with dx tranny and flywheel
- turning problem
- y7 head on a6 block ?
- D-series Spark Plug Tube Seals in Valve Cover Removal
- Just bought a 89 Civic. Multiple Questions and praises. Please read. New to Forum
- Anyone running a Autozone master cylinder?
- 89 crx si Electrical problem need help
- car woes
- B+G Springs, whos used them????
- oil leak
- Crx Slick Sizes
- yet another h22 problem help!!!!!!!
- yet another screwy idle - symptoms!
- 88 dx cluster wiring and 90-93 integra cluster wiring needed.
- crank timing
- Eggman's EF in Super Street
- 90' civic help!!
- jim fab trac bar. stupid question. sorry..
- tuning 1g safc
- Wagon Suspension Upgrade
- Dragging noise when I let off the clutch
- 89 Honda Civic: Weird fuel problem
- Need help on two factory cams for my 91-DX with MPFI swap...
- Good deal on 89' Civic?
- Why do people want a 300_+ hp Ef ?
- Where can I see the spec and pics of a high powered CRX? 400HP+
- My Sensor!?
- Gen 2 sunroof's and has anyone made a glass one or is it impossible?
- Throwing Code 7
- turbo for my B16?
- Wheel offset
- What brake setup front/rear?
- 1991 Honda CRX Engine swap B18C5 DOHC VTEC type R
- Si tranny swap?
- VAFC Help w/ B16/B20 CRX
- 90 civic check engine light up, code 8
- bad axle?
- B16A CRX WITH OBD1 smog ??
- swap extras?
- Access Motors two thumbs up
- H22a swap
- Question from New Vtec user
- engine harness question
- Lime Away for CRX parts Q?
- Need some tips/advice. What do you think? **3 vids included**
- IACV question for B16A1
- sir front end conversion question????
- shop that will install my es bushing kit + rear trailing arm.
- door buzzer problem
- Retrofit HID in a stock CRX headlight.
- car won't star (searched)
- axels for b16 need to replace. of what car?
- Crx Rear seats?
- B18c1 or B20...Your Thoughts
- my new crx help me get her home
- Damage from my wreck - Best course of action?
- 1991 CRX SI engine swaping a b18c5 type r
- HELP...What is this
- Difference between JDM and USDM fogs. Write up.
- Mini me tuning
- idle question
- skunk 2 intake manifold
- gauge cluster Si to Sir HELP!!!
- starting problems?
- I searched but could not find. please help
- LET ME SEE YOUR CRX WITH AN AFTERMARKET FRONT X-MEMBER
- a good radiator
- 87 Civic Si needs a swap
- B16 in 91 si hatch won't start
- vss causing vtec not to engage?
- amber bumper lenses
- FITV Question Please Help(B16A1)
- Just got my Harness from Rywire :)
- Numbers on rad cap?
- need opinion
- 90' civic brakes
- My Engine Rev's on Idol
- need help! D15B2 to D15B engine swap trouble.
- ZC/ D series DOHC performance manifold - NA application
- anyone want to buy an ls?
- WEIRD PROBLEMS WIT MY B16 ODB0
- OBD0 to OBD1 conversion harness Wiring Diagram (searched)
- oil temp sensor
- egr valve
- with this fit
- ZC+D15B What T-Belt?
- How do i do a compression check???
- EF Swap options...
- After boost where does one go for vacuum source ?
- WILL VX RIMS FIT CRX SI? CLEAR CALIPER
- Knocking in motor
- Look at my B16 Turbo 1/4 Times...On steelies
- 2nd Gen ZC Swap Information
- Chicagoland brake vacuuming shop???
- What's The difference?
- disk and drum, is the e brake cable different?
- coil overs
- please help
- what year of VW's front lip would fit good on our front bumpers ....
- KYB Agx struts or the Koni Yellows....with my DIY extened rear top hats
- wide body crx
- reverse lights, already searched
- accelleration problem!
- usdm ef civic hatch rear lip?
- could i do a mini me / delsol sohc vtec??
- zc dohc or sohc
- Idle problems for b16a1
- sry cant post in auto section, For Sale 89 Honda Crx Dx in So Cal......
- I believe I'm missing a pulley
- 88-89 civic 4 door corner lights....will they fit 88-89 3 door civic?
- what colour
- ecu question
- MPFI HELP FAST PLZ!
- obd0 to obd2?
- need parts
- rust repair patch panels
- Can anyone help a kid out?
- Weapon-R ram air kit- where do i put the scoop?
- d-series axles HELP!!
- B16A in '91 CRX Clutch problem
- Evercoat gold Gallon vs. XL micro quart?
- dsm injectors
- Need help car just dies when rev'ed
- Want to know , where i can get a EF9 Bronze Glass in socal
- COOLANT SMELLS LIKE GAS
- Air Bags VS. Coil Overs
- FS: 90' CRX si MPFI swap, poly shift bushing, flowmaster muffler, amplifier, intake
- resecuring bumper?
- obd0 b16a throttlebody/ car idles high
- crx suspension
- ZC block and head
- omnipower redesign of full coilovers for CRX
- Head warpage how much is too much
- rad fluid overflowing
- 90 CRX W/ JDM d15b code 7???????
- HELP!!!!
- timing
- I need help with my exhaust
- EF A/C GURUS???
- HELP!!! ???QUESTIONS??? ON SOHC SWAP!!!!
- b16 headers..which one??!?!?!
- code 9 help??
- b16a head on a b18a1 block
- gas tank Venting??? on Crx b16 swap.
- what is cel code 6?????
- back again bitchs
- Picture of where to dent for alternator?
- Neep oppinions on what color to paint my crx
- wtb ls
- help with what clutch to put in my car....
- 91 civic, ac makes noise like grinding metal noise...help
- Axels?
- I NEED EVERYBODYS HELP OPNION I DONT KNOW WHATS WRONG
- Crunchy 3rd gear. Any help?
- blown headgasket
- i need a answer
- WTB: 90-91 CRX Fenders Washington Area
- intake manifold
- CRX VAFC Q?
- Ls not running right
- rant: si mufflers dont fit and dx or other model
- Recomended Tools
- B16A1 problem, please help
- How much did you pay total for your swap?
- Need help installing keyless door handles.
- upper control arm ball joints on an 88crx
- FAQ how-to install a Walbro fuel pump into CRX
- Gettin BOOSTED
- FS: 1990 CRX HF, rolling chassis.
- dumb question on zc or b18
- header gasket Question
- 91 civic dx swap
- Nothing I can do to remove CODE 6!
- Yet another battery light question...
- WTF!?
- WTB: EF9 Corner Lamp
- 1st gen crx question!!!!!!!!! HELP radiator support!!!!!!!!
- ls turbo?
- SOHC Vtec Questions
- vafc I for obd0 vtec?
- crx front bumper lip
- '89 CRX w/ B16A running VERY rich
- EF hatch/CRX room comparison
- 90-91 CRX taillights are sooo much prettier than 88-89.
- what do you guys think
- how do i
- dont know why my b16a1 swaped rex is misfiring at 5000
- Catback Exhaust for CRXs?
- Newbie: Should I trade my Katana for this CRX?
- Weird VTEC engagement?
- Comprehensive CRX glass roof top installation instructions
- All aings point to headgasket but headgasket checks out okay?????????????? pls help
- prelude dash conversion gauges help.
- b16a wont go into vtec
- b16crx wire problem,vafc queston
- safc-II install questions
- Wedge brackets
- zc plug gap
- crane a6 cams in 92-95 dx head
- b18a1 ques
- Need help with OEM CRX Fog installation.
- what frnt bumper will fit.
- ebrake cable to short
- Delsol wheels??
- Weird problem with brakes on my 89 hatch...
- Distributor labling
- Lowering Springs
- b18c1 horse power?
- Where are the vin #'s located?
