Ef hatch B18 A/c Help!!!!!!
Old Jun 22, 2015 | 11:22 PM
EfB18's Avatar
Default Ef hatch B18 A/c Help!!!!!!
Hello i have a 1990 civic hatch with a b18 swap in with no a/c or p/s and i was told putting a/c could not be done because of the lack of space is this true or can i install a/c altering/combing diffrent parts?
Old Jun 23, 2015 | 09:37 PM
Ef4doorwagon's Avatar
Default Re: Ef hatch B18 A/c Help!!!!!!
You have to use your stock compressor and lines, and use a hasport ac bracket that allows you to bolt it to the engine. There's also a thread here somewhere where someone used the innovative ffront cross member( to clear up space) and used his stock compressor with stock bracket and made it work.
Old Jun 23, 2015 | 10:20 PM
EfB18's Avatar
The stock d series one ?
Old Jun 23, 2015 | 11:11 PM
_EF9's Avatar
Yes. I just tried this last month. B series compressor and bracket will hit your crossmember, no clearance unless you want to notch it up. Not recommended. Innovative and Hasport makes a bracket that will take your stock d16 compressor to fit your b series motor. But I believe that those 2 only take Sanden compressors. From what I read before, there are 2 different compressor for d16s? Good luck
Old Jun 24, 2015 | 10:02 AM
Hasport's Avatar
the hasport bracket EFBAC works with the factory sanden compressor and matsushita compressor
dijitalbuddhist
15
Mar 3, 2014 09:33 PM
McKinky
Mar 11, 2013 11:06 PM
brownsEF
Jul 3, 2011 02:05 PM
moco_machine
Sep 4, 2009 07:26 PM
on2wheels
10
Dec 8, 2005 01:15 PM
