View Full Version : Honda CRX / EF Civic (1988 - 1991)
- I'm looking for weight specs.........
- Why lowering springs do not lower the front end as much as we like it to.
- zc questions
- difference in std exhaust manifold and hf/cx manifold ?
- Just Wondering
- quiet exhaust
- Intake manifold sensors/connectors.
- Suspension Technique or Neuspeed Sway-bar and Bushings?
- Si crankshaft in an HF block?
- anybody with b16 swap in Toronto?
- Spoon calipers in EF8, 4 or 5 lugs....it is the question?
- 92+ Civic, 94+ Integra Seats into a 88~91 CRX???
- pix of DSM intercool on a CRX???
- Carbed SOHC??
- planting the rear on a crx.. :)
- Would missing a gear mess up my motor?
- Anyone know how to put cruise control on a crx??
- worth my effort or no?
- JDM d15 DX motor?
- Which mount kit HCP or hasport
- YS1 GSR Tranny bolts up?
- EF Civic and Crx doors
- Arizona HT meet in Feb/March??? link to members corner.
- ED rally car project.
- low enough?
- ITR Lower Control Arms on 4G Civic Hatch???
- Anybody know where i can order the inner balance draw for my b16a1?
- 9.5" to 11" brake conversion, where to buy?
- Hate the winter: (pics of parts to come)
- Shifter wobbly, Can it be adjusted to be tougher?
- Steering wheel hobbles after hitting small bumps in road
- SiR tag part number#?
- 4DR specification sites??
- read 3 pages of search, still need IDLE help
- 91 B18a or (JDM) B16a1
- Will a 88 crx si engein d1616 fit into a 87 crx si mpfi???
- Anyone ever replaced wheel bearings?
- Where to buy a gauge face or even the cluster for the b16a??
- d16a6 clutch...does it matter?
- rear disc conversion??
- Ls/Vtec or Ls turbo Which one
- **So many options with DC header & emissions!! Which is best??
- crx and or civic for sale (clean)
- Which VSS to use with GSR cluster?
- whats needed to swap an ls motor in hatch?
- Whats better?
- camber kits??
- Antenna Delete Plate on cars without Radios?
- Hi, Im New
- civic and or crc for sale
- chasis codes
- growl hub assembly question!!
- hf hp
- i need crx help
- Wiper nozzles
- side skirts
- Need suggestions on 90 crx si seats
- airbox removal question and linkage question
- Wiring/making a start panel
- ef9 parts for sale
- what to do when you F*ck Up on your brakes
- map sonsor on the crx?
- goodbye B16a... let me know what you think...
- turbo piping q?
- Need help on a part, its rice but an OEM part.
- Where to buy that little panel in the dash???
- this question is dumb....
- '89 DOHC Integra Motor into 90 Civic Hatch. What's needed???
- sun roof
- my camber sucks
- 89 hf with a b16
- Using Wheel Spacers on front and rear?
- clutch cable position
- how to check if distributor is good?
- Could someone please humor my friend?
- zc tranny guru's
- CRX Resource is back online!
- need some stiff new springs???(searched but confused)
- vibrant short shifters...
- air strut
- Jdm crx climate control
- which o2 sensor...... results & bang for the $
- What would i need??
- Crx ecu problem...
- Pan-American nationals... Florida!
- Changing the timing belt
- pic of CRX Si center cap
- Any has a revolution exhaust on thier car?
- CRX and Civic mirrors same?
- Need help with ntsc return line.
- Anyone get their gsr cluster odo to match their stock one?
- intermediate shaft question????
- gsr cluster, this is old school and i've searched and this is not on the forums
- So is a SOHC ZC the EXACT same as d16a6?
- The last of the problems for my crx.
- how common is this color?
- SiR front/rear brakes...which aftermarket rotors and pads to buy?
- rear tranny mount
- Brembo rotor install?
- MPFI swap. 3500 RPM revlimiter WTF?...
- CRX dash options
- Is this d16y8 intake manifold from a auto or manual, and why does it matter?
- will teg MC and booster fit ?
- LS motor in a Civic/CRX questions
- big problem w/ hub assembly , cars needs 2 b out from where it is tomorrow a.m.
- Any way to tell if this is an Si?
- h&r race spring rates and ground control spring rates
- NY/NJ meet jan. 20th
- Idle problem
- sesfront sway bar ??ion
- Teggie cluster in a civic
- sir bumper quesiton???
- camber kits for an ef
- Putting out a feeler for my ZC tranny
- do jmd hatchs have locks on both sides?
- B16A in 1st Gen CRX, Which Header Will Fit?
- nut on alternator...how to remove?
- sohc nonvtec ZC with tranny
- What clutch for my Y1???
- Part # for lower timing cover seal??
- ITR suspension on an 88 dx hatch possible?
- Rear drum adjustment
- Tanabe Hyper Medallion on HB
- Recommendations on ideal timing setting
- How do you change a rear wheel bearing?
- anybody have any exhaust sound clips?
- Are JDM Tail Lights a straight bolt-in?
- clutch wont engage
- 91 crx si with zc and 88si tranny/ what clutch/flywheel and what axles?
- LS/Vtec
- anyone running sprint springs?????
- window crank replacement?
- LOUD squeeking noise when i turn steering wheel..
- CRX DC header (4-2-1) on my Z6...questions
- Need help right away, having problems
- Swap info??
- Does anyone know the wiring conversion for 95 D16Z6 into an 89 CRX.
- D series swap question ..........
- f'cked ignition switch?
- I can use this gauge cluster, right?
- Greddy header for B16 CRX
- 240sx Front Lip on Hatch
- What timing belt for d15 block with d16 head
- Can anyone vouch for Wes d or niedejb???
- rpm meter
- D-series Question
- Cant get the axle nut off.
- my ECU keeps blinking??? no stop!!
- donor car questions
- tried a search but there is no info on CODE 13!!
- engine side harness from 90si work in 89hf?
- Need advice on my car
- Farewell to a fallen CRX
- Internal suggestions for the b16a?
- best classifieds
- Just ran my exaust (myself). wondering if you guys see any drawbacks?
- has anyone done this?
- changing final drive in ZC tranny
- How much slower is a DX tranny than a SI????
- Main Shaft Bearing Transplant (Si to Si)
- Sh*t can or fix up?
- Major problems, please help out, guys !!!
- crx in burnout contest
- Does anyone have the dimension of a crx?
- car over heating...
- 90-93 teg axles--auto same as manual?
- Details on Opening A Corner Light?
- help please problem with my rex
- My How-To on Replacing a Broken Wheel Stud
- code 15??
- JDM Y1 tranny gurus.
- my crx goes bye bye tomorrow
- swap shop?
- Problem with low beam headlights. (Did search through 7+ pages) Please help
- Fuel pump?
- Damn!!! Little spot of rust by rear wheel well.
- oil on plugs good or bad
- steve @ passwordjdm.com is awesome
- neuspeed/kyb agk
- Quick ZC question
- Suspension setups on 1st gen CRX (85-87)
- guys in the philadelphia area using pr3 ecus
- Help with Honda to Acura conversion capability and General ?'s
- Quick question!! What size socket for the axle nuts on a 89 STD??
- Anyone with pillar gauge pods in their CRX?
- Extra plugs after swap?
- Stock Spring rates for 90 Civic Hatchback DX?
- Apexi V-afc compatability
- Chip my b17 setup?
- teins springs??
- crx springs.
- Check engine light comes on some times. But why ?
- Needing help with custom turbo kit!
- for those with gsr seats in their CRX...
- B16A vs B18B/LS vtec
- new injectors
- throwing codes need help
- md/dc/va wrecking yard location
- Whats the difference b/w these motors?
- Which color 1G CRX...
- need help with wiring...
- Head Project Started!
- CRX SiR carbon fiber hood wont hold down
- where to install a/f ratio gauge
- doing heavy lightening to ef hatch body, what all can i take out
- Si 2nd headlights (with lense) into EF8? Is possible?
- i need some help.
- best, beautifoul and light 16" wheel for EF? (4 or 5 lugs)
- just threw code 16!!
- HELP! B16 idle fluxuation, already tried search..
- Whats the problem?
- 88-91 d15/d16 spline count....
- growl couldnt find in search. b16 swap questions. 97% done though!
- Consider buying a 89 CRX/Civic HF
- Honda Civic 96 LX Engine Swap
- how to take off window crank thing...
- abs in crx
- !!!today is a great day for me!!!!!
- Just finished rotor/pad install- Is this normal?
- '93 honda lx d15b7 into '90 honda lx
- Axle wont come out (Hub side, Pictures Included)
- civic type r cam & type r cam in b16a1
- Finally figured out why I'm losing power when cornering
- What shocks to get for 88 CRX with ground control's?
- power steering in my ef how?
- Yarr!
- Calling all MPFI swap experts, couple errors found in mine...
- Vtec problem, different than most... (did search) HELP!!
- front bumper question
- a6 head question...any diff. between 4wd and regular civic/crx?
- new bumper for 89 hatch
- DPFI to MPFI swap gone wrong!!
- Ignorant people just don't quit...
- check this out
- Si engine Price tag? Where to find a good ZC?
- crx's are poor mans cars..lol.. read...
- Engine Light
- 91 Si Exhaust mod. comments?
- European Guage Clusters...are the available over here?
- What should i ask for my car if i decide to sell it??
- morning starts rough please help
- how can code 43 even invovle fuel (nonobd)
- LS\VTEC info
- coilovers
- anyone have a pic of the hks sport exhaust??
- 6-Speed Manual AWD '89 Wagon?
- Buying a 1991 Civic Si
- rear speakers in a hatch?
- Key Lock Cylinder
- you know your car is going down hill when
